Open Source DIY PHEV Conversion
Discussion in 'Prius PHEV Plug-In Modifications' started by boone, Nov 12, 2012.
  1. boone
    boone Junior Member
    Charlottesville, VA
    I was on here 6-8 weeks ago (mid-Sept) and somewhere in one of the threads someone stated their intention to do a PIS-like 10kwh (I think) conversion, and then make a list of parts and steps available as open source DIY. I've been scanning back through threads, and can't find the reference. Are you out there? Are you doing this? Any update? Thanks much!
  2. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    The only thread I am aware of is this one but it is for a 4kwh PIS kit.
    PIS 4kwh PHEV kit assembly and installation odyssey | PriusChat
    Parts like the front and rear controller (including the mythical ICE ECU spoofer) I would only source from PIS as then you would know that the firmware is all up to date and then you could receive new firmware updates.. The rest can be sourced directly from a supplier.
  3. usnavystgc
    3,159
    989
    Tucson, AZ
    I think you're talking about the YaPiP project. Jdh is still working on it. See his thread.
