Open vents to outside air. . .
Discussion in 'Gen 4 Prius Main Forum' started by Junepak, Jul 19, 2016.
  1. Junepak
    Junepak Junior Member
    Chicago
    I noticed one of the adjustments for the Carista 3.0 is to Open vents to outside air when ignition is turned off. The factory default was set to *Yes*. I changed it to No because I was thinking when it's really warm outside (I live in warmer part of silicon valley) and you crank up the A/C and then park outdoors, opening the vents to the outside will warm the car faster.
    Can I get some advice on whether my assumption is correct or not?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    The Manual says it's to "... encourage better air circulation through the vehicle helping to reduce odors ...". I imagine very little air-flow would occur without a fan operating (I can't ever feel it even with a gale blowing), but open vents could reduce pressures when doors are slammed or the air expands as it heats up.
  3. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    Does anyone have a list of the parameters that are hidden? Will the dealer make adjustments to these?
  4. fuzzy1
    10,164
    I'm guessing that when the car is shut off, the air exchange rate through the vents is negligible compared to the normal solar heat radiation through the windows and thermal conduction through the glass and wall and ceiling panels. The vent setting would be more for longer term moisture and odor control, maybe dust too.
    Let us know if you find more detail.
    Junepak and alanclarkeau like this.
  5. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    I thought it was set to yes to let the mice in. Or is that just a Gen 2/Gen3 feature?
    kithmo, fuzzy1 and CR94 like this.
  6. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    I agree with fuzzy1 and alanclarkeau that the thermal effect will be very small. The small ventilating effect would indeed cause the interior to warm slightly faster initially in those circumstances, as you assumed, but it would slightly reduce the subsequent rise above ambient temperature due to sun.
    Whether that setting affects risk of mouse entry is a more interesting question.
    Junepak, fuzzy1 and alanclarkeau like this.
  7. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Whether parked or moving, I keep my air recirc closed at all times. Just for the fact that so much more dust seems to come in the car when it's open. And in the Gen4, all those black pieces really attract dust. (Plus the AC works better.)
    Junepak likes this.
  8. MrMischief
    426
    443
    Denver CO
    Did you use Carista to override the feature where the vents open once the Prius is turned off?
  9. pakitt
    pakitt Senior Member
    2,173
    1,311
    Colorado
    Most parameters are listed in the user manual. Others are visible with Carista.
    Yes, Carista is one (or the) way to do it.
  10. Autoist
    Autoist Member
    119
    81
    Seattle Metro
    I think all the options I found in Carista are also listed in the manual starting p.752
