Opened gas cap while car was on..
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Priusdemon, Sep 20, 2024 at 10:24 PM.
  1. Priusdemon
    Priusdemon New Member
    Friday
    I
    Went to the gas station and opened the gas cap while car was on and pressure released from the gas cap.. ever since the. The engine won’t go to idol when using the electric motor, and when I come to a stop the engine switches on and off, messing up the mileage I could be saving from using electric… I switch the mass air sensor and the check engine light went off but the car ain’t running the same. Is it a quick fix, and does it have anything to do with the pressure in the engine itself?
  2. Tombukt2
    Tombukt2 Senior Member
    9,985
    1,730
    Durham NC
    Car on in this description means engine running?
  3. Mendel Leisk
    38,990
    #3 Mendel Leisk, Sep 21, 2024 at 12:02 PM
  4. BiomedO1
    BiomedO1 Senior Member
    1,666
    863
    SacTown, Ca
    I'm surprised you didn't get an Evap error code.
    the car needs to be scanned to see what's causing your issues.
