Operation Volvo Seats In A Prius Part 2
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Wildkow, Jul 15, 2008.
  1. Wildkow
    Wildkow New Member
    5,270
    37
    36
    First things first . . .
    Disclaimer
    Disclaimer: DIY automotive work, like any project involving machines, can be hazardous if appropriate safety precautions are not observed. DIY Prius modifications are particularly dangerous because they often lack the redundant safety features of commercial and or professional Prius modifications. This site and in particular this topic is intended for informational, not instructional, purposes. Attempt/build at your own risk. Be careful! As anyone can tell I haven't the faintest idea what I'm doing, therefore DON'T do these things they could kill or seriously injure you!
    OK here’s part one, Removing the Front Seat. You need a 14 mm socket and there are only 4 bolts and three electrical connectors to remove. If anyone can let me know of some good info sources on the wiring harness, electrical, airbags etc. etc. I would certainly appreciate it.
    [ame=http://www.youtube.com/watch?v=RLPL-23e4Os]YouTube - Prius Removing Front Driver Seat[/ame]
    View attachment Prius driver seat electrical connections 2006 pkg 6 with comments.pdf
    View attachment Right Front Bracket w-comments.pdf
    View attachment Volvo left front drivers seat mounting bracket with comments.pdf
    Hope this helps any suggestions?
    Interesting page . . . Airbag - Supplementa Restraint Systems - The Lemurzone Airbag Pages
    Wildkow
    p.s. How about somebody help me actually "bleep" out the comments usinf Nero Express 5 instead of just playing the comment and the "bleep" at the same time?
    *** WARNING *** WARNING *** WARNING ***
    NOTICE :
    When inspecting or repairing the SRS, perform service in accordance with the following precautionary instructions and the procedure, and precautions in the Repair Manual applicable for the model year.
    ∗ Malfunction symptoms of the SRS are difficult to confirm, so the DTCs become the most important source of information when troubleshooting. When troubleshooting the SRS, always inspect the DTCs before disconnecting
    the battery.
    ∗ Work must be started more than 90 seconds after the power SW is pushed to the "OFF" position and the negative (–) terminal cable is disconnected from the battery. (The SRS is equipped with a back–up power source so that if work is started within 90 seconds from disconnecting the negative (–) terminal cable of the battery, the SRS may deploy. )
  2. problemchild
    problemchild New Member
    429
    36
    There is much more to this then meets the eye. Its well worth the endeavor. I congratulate you for your efforts.
  3. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    More information is always better - so thanks for providing some on a great topic! :)
  4. Wildkow
    Wildkow New Member
    5,270
    37
    36
    OK I signed up for Toyota’s TIS (Technical Information System) subscription
    for one month $50.00. This is a really neat system and full of information,
    diagrams and schematics. Here is what I have found so far . . .
    CAUTION:
    • The vehicle is equipped with a Supplemental Restraint System (SRS),
    which consists of a steering pad, front passenger airbag, curtain shield airbag, front
    seat side airbag, seat belt pretensioner, center airbag sensor, front airbag sensor,
    side airbag sensor, rear airbag sensor, occupant classification ECU and seat position
    airbag sensor. Failure to carry out service procedures in the correct sequence could
    cause SRS parts to unexpectedly deploy and possibly lead to serious injuries.
    Furthermore, if a mistake is made when service SRS parts, they may fail to operate
    when required. Before performing servicing (including installation/removal, inspection
    and replacement of parts), be sure to read the following precautions.
    • Before starting work, wait at least 90 seconds after the power switch is
    turned OFF and after the cable of the negative (-) battery terminal is disconnected.
    (SRS parts are equipped with a back-up power source. If work is started within
    90 seconds of turning the power switch OFF and disconnecting the cable from the
    negative (-) battery terminal, SRS parts may deploy.)
    (The SRS is equipped with a back-up power source, so if work is started within
    90 seconds of disconnecting the negative (-) terminal cable of the battery, the SRS may be deployed).
    • Do not expose the steering pad, front passenger airbag, center airbag
    sensor, front airbag sensor, front seat inner belt, seat position airbag sensor,
    occupant classification ECU, front seat airbag, side airbag sensor, curtain shield
    airbag, rear seat airbag, rear airbag sensor,
    DO NOT TURN ON THE POWER
    WITH THE SEATS DISCONNECTED!
  5. problemchild
    429
    36
    The drivers seat gives you two options. You resistor off the airbag or you connect it.
    The passenger seat is the same but you have to deal with the weight sensors. If you could buy a pass. seat from a junk yard you could cut the sensors off and hook them up which will get rid of the AB warning on the dash.
    Have I reminded you NOT TO TURN ON THE POWER WITH THE SEATS DISCONNECTED YET?
  6. Wildkow
    Wildkow New Member
    5,270
    37
    36
    Yep you just did! :p
  7. Jack66
    766
    Stafford, Virginia
    This really good, Wildkow. I have planned on signing up for a one-day TIS subscription on Friday and download all weekend. I keep getting sidetracked and my goal is to try again this Friday. The new baby keeps me busy and I want the weekend to get through the downloads.
    I am wondering if the Prius seats can be made to be more Vovlo-like. At some point I would like to ask a professional upholsterer (sp?) if they could use the Prius seat frames as the starting point, leave the sensors and airbags, and rebuild from there. Maybe a special addition for seat height adjustment? Maybe THAT is a modification that Hybrid Effects should look into. There would be a booming business.
  8. Wildkow
    Wildkow New Member
    5,270
    37
    36
    I'm trying to figure out a way to swap the Prius mounting hardware over to the Volvo seats. The problem as problemchild has pointed out in his topic on this subject is the height change and the offset. IF the swap is possible it will (hopefully) take care of the questions regarding the seat position airbag sensor. I am still looking for help on the actual operation of the SRS system and the sensors, anyone?
    Wildkow
  9. problemchild
    429
    36
    I custom fabricated some brackets to mount my seats. At some point I will make some better brackets. I had to move quick as the HORRIBLE PRII seats were killing my back. I actually parked my new prius and was driving my 2500 4x4 diesel at the tune of 75/day in fuel.
  10. Wildkow
    Wildkow New Member
    5,270
    37
    36
    Hey Jack
    Yeah that's a good idea. Strip it down to the metal and transfer the cushions and leather over to the Prius. May have to customize the frame a bit but I'll wager that most of the shape comes from the cushions and not the frame anyway. If you're the only one that drives it there is not much need for all the fancy schmancy electric stuff. The one thing that would be nice for you would be the heated seats and thats already available as an add-on or it could be taken from the Volvo seats and transfered over. By the way I weighed the seats the Prius seats weigh about 40 lbs and the Volvo seats with all the stuff in them weigh 62 lbs. So far from my research the only thing that maybe a problem as far as the SRS (Supplemental Restraint System) is concerned is the seat position sensor and all that does is signal the front airbag to deploy faster or slower according to the closeness of the seat to the steering wheel. Personally if I can't figure out a way to make it work as intended I will just set it to deploy slower since if you're using the seat belts correctly that should be sufficient in just about every circumstances. The only other problem is the offset of the seats that forced problemchild to place the passenger seat in the driver area and the drivers seat in the passenger side. This places the side airbag on the wrong side but you still have the side curtain airbag for your head and that is the most important one. I think I was a bit optimistic in my one week project estimation.
    QUESTION: Problemchild, can you elaborate a bit more on why the offset of the seats won't let you place them on the correct side?
    Wildkow
    p.s. BTW all thanks for the encouragement, at least I'm now able to return the favor to all the other good people here that have contributed their knowledge, sweat and blood to make the Prius a better car.
  11. Jack66
    766
    Stafford, Virginia
    I'll log into TIS this weekend and take a look at what basic seat functions need to remain, what could be moved, and how much space can be created. I am interested in getting the car interior in a CAD program and looking at different options for seat designs. I like what ProblemChild did with his Volvo seats but my wife won't get in the car or let the kids get in the car if she has any doubt about impaired SRS.
    Seat height isn't an issue for me or my wife but it is a big issue for others so I am interested in finding a solution. If I can get Volvo-like cushioning on my Prius seat frames that leaves the sensors and doesn't affect the SRS then I would have everything I want.
  12. problemchild
    429
    36
    Keep in mind the airbags could be connected if you think the prius detonation signal matches the volvo seat charge. It would not do any harm to hook it up. Also the only airbag that may/may not detonate is the tiny handkerchief size airbag that protects your ribs/torso. All other airbags will detonate.
  13. Jack66
    766
    Stafford, Virginia
    Good point - I forgot that I wanted to get on TIS to check the charge for the SRS firing.
    I liked your edited signature...
  14. dwreed3rd
    dwreed3rd New Member
    742
    Marietta, Ga
    Hey! I reall don't want to be a spoil sport, but a question came to mimd yesterday re: seat modifications in the prius. I can understand if they're outside of warranty or you don't care about any portential warrany problems with the seats if you consider the comfort is worth the risk. But what about insurance? With all the rules and regulations regarding crash ratings and air-bags and and selt belts and all the maintenence warning label. I'm wandering if an insurance company may reject a claim if they discover the seats had been modified by other than a certified technician. Any thoughts along those lines?
  15. mrblaise
    mrblaise Go Lakers!!
    2,248
    525
    Southern California
    I have many thoughts along those lines since I'm in the legal field and deal with insurance companies on a daily basis. Any modification that causes or contributes to an injury or fails to eliminate a risk of injury may cause a claim to be questioned. Further, air bags are designed for a particular cabin space in mind. Air bag deployment in a "correct" cabin space can cause serious injury while protecting one from other potential injuries. An air bag too large for a cabin space could potentially cause "very" serious injury. In addition, your quoted insurance takes into consideration certain aspects of a car's safety mechanisms. If they're removed or tampered with, an insurance company could conceivably argue fraud in the contract. Just two simple points to consider. Some here don't want to consider such things. But, I think it's always better to weigh "all" the potential risks, then make your considered decision. That's my last thought on the subject as I don't want any "thread hijacking" talk to erupt. lol
  16. dwreed3rd
    742
    Marietta, Ga
    Thank you mrblaise! I don't think you're hijacking the thread. This is exactly the kind of information we need to know. You go to the game with the facts. How you play is your choice. But I want to know what the pros and cons are so that I can make intelligent decisions. Or maybe emotional, but at least I what to know the trade offs.
    Thanks again for the post.
  17. problemchild
    429
    36
    Blaser felt the need to bring this up in every thread I posted about seats or seat rails. He even helped get the group seat rail manufacture killed.
    1.) He has NO intention of installing volvo seats.
    2.) If he is not installing the seats there is no need for him to post.
    3.) I'll go get some popcorn as I can see the way this thread is going to go now. 40 pages of negative ranting and 1 or 2 posts about volvo seat installation.
  18. mrblaise
    2,248
    525
    Southern California
    Listen P.C., someone asked a question in a field where I'm highly knowledgeable. I said that it was going to be my only post on the subject and it will be. I'm only posting to you as I really don't know why you're so against someone voicing an opinion when an on-topic question has been asked. If no one would have asked the question, I wouldn't have responded. Some one did, so "I" did. Simple as that. I'm not going to remain silent simply because it may ruffle your emotionally charged feathers. I didn't bring it up, so why don't you get off my case.Further, I didn't help to get anything "killed". I, and others who care about safety, probably saved others from "getting" killed. I sincerely hope your projects and those of others work well. However, I'm not going to ignore a safety issue if someone asks a valid question, which is exactly what happened in this thread. :)
  19. dwreed3rd
    742
    Marietta, Ga
    His post is alot more informaional than a political signature. And it's exactly the type of information I'm looking for in a forum. I want to know the pros and cons so that I can try to make an intellegent decision. He may not have been considering VolVo seats, it but I was. I'm the one that asked the question. He gave what I thought was a thoughtful responce. I believe it is a valid concern. Are you saying that it is not a valid concern? Or, if it is valid, that he should not have warned me. If not then share with us why it isn't a valid concern. If you want to roll the dice with you insurance company, that's your choice, and I support your right to make that choise. But why would you want to begrudge me the right to make my own choice. Perhaps he has been posting it in other threads. However, Ive been crawling all over PC for weeks and do not recall seeing it. It was a precise answer to my question. Perhaps I have the wrong impression if what PC is all about. The thought the purpose of PC, was to have a place where Prius owners, or anyone wanting to learn about the Prius, could go to ask questions, learn, and disseminate information, and it's O.K. to disagree on an issue. But not to censure opinions that you don't want to hear. You said he got the seat rail manufacture killed. Did he personally, on his own stop it. Or, was it because he made others aware of the concerns and they made an informed decision that they didn't want to take the risk. If you can show why he's wrong, I would like to hear that here too. I was really turned on by the Volvo seat and was actually looking at online salvage yards to see what kind of $$$ we were talking about. But if I understand your position, he should have not warned me, and if it is true, and I had an accident, and the insurance company denied my claim, Well that's just my tough luck.
    I respect Richard Shumacher's opinion re: No city needs the "B" mode. I don't agree, but I respect it. The difference is that Richard gave information to support his position. I'll check it out when I get our Prius, and I'll share my information with him whatever the results. We both will have learned something. That's the kind of interchanging of idea's I thought PC was about.
  20. Jack66
    766
    Stafford, Virginia
    Don't fret, dwreed3rd, PC is what you were expecting it to be. Unfortunately your previous search probably used the normal PC search feature which rarely finds what you are looking for. Also, Problemchild is referring to a thread where he just wanted to show folks how his project to install Volvo seats in his Prius was going. Problemchild was concerned that safety concerns were overtaking the fact that his thread was for others information. The safety concerns were valid to bring up so readers could make informed decisions but it got a little out of hand.
    Mrblaise has a valid point and my entire design concept (its only a model) relies on leaving the Prius safety features untouched. Problemchild's installation exchanged the Prius seats for Volvo seats and he explains why he did that and that the risks were acceptable. I feel the same way he does about the Volvo seats and would do the same in a New York minute if I didn't have others to think about. My compromise is intended to keep safety, reduce the risk of a possible rejected insurance claim, and add comfort to a car that I love.
    By the way, the burden of proving a modification voids a warranty is on the organization trying to void it. There are numerous posts and websites on the subject. What keeps Toyota from voiding your warranty because you put seat covers on or change your own oil?
