Opinion=2008 Prius 111k miles-Is it still a reliable car?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Aug 15, 2019.
  1. ski.dive
    ski.dive Active Member
    899
    233
    Hutchinson Island,FL. Mt. Snow,VT
    SERVICES DONE:
    -I've done ALL the Toyota recalls
    -All fluid changes-Synthetic oil every 5k miles+ Coolant & Tranny Fluids
    -New tires-Replaced 4times
    -12v battery-Replaced 2times
    -Recent New paint job & Headlights
    ***EVERYTHING ELSE ON MY 2008 IS ORIGINAL
    Data Daedalus likes this.
  2. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    Depends how you define "reliable", doesn't it? Mine starts every day, gets me where I'm going, and then home again.
    Raytheeagle and Data Daedalus like this.
  3. Data Daedalus
    Data Daedalus Senior Member
    1,024
    1,184
    Wembley, London
    If my UK 2008 Tspirit (top of the range) is anything to go by at 116.6k UK miles, I’d say yes.
    Does a 34 mile round trip commute every day, and apart from one 12v battery (2014?) and a rattling water pump at 99k, it’s been delightfully faultless.
    I’d wager there’s at the very least up to 200,000 miles of running with that level of care before anything should really go wrong. It may easily cruise beyond that.
    Indeed, 300,000 isn’t uncommon on a well treated Prius. As long as you’re not living in Nevada, the HV battery shouldn’t easily succumb to climate induced roasting.
    Drive it normally and you could well stretch it to 350k or 400k.
    iPad ? Pro
  4. Moving Right Along
    Moving Right Along Senior Member
    690
    541
    Your question can have different answers depending on the car’s situation. I would contend that a 2008 Prius that you own is definitely reliable enough to be worth keeping, especially with the work you put into it.
    I’d say it would be a reliable car to buy even if someone else did that work, but that’s more up for debate.
  5. bisco
    49,574
    2008 is a beast. i would expect 200 - 250k without any major breakdowns
  6. JC91006
    16,488
    8,402
    If this question was asked 5 years ago with the same mileage, answer would be "this car is very reliable and won't let you down".
    Asking the question in 2019, "this car should be reliable and possibly not let you down"
  7. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Would you buy a new car if everyone said no? I would say less reliable than new but it’s paid for. Get the good AAA towing package and bank your new car money for the future. Figure the battery is gonna go somewhere in the next few years.
  8. Patrick Wong
    18,200
    6,479
    While the 2G Prius is more reliable than many used cars of similar vintage and odometer reading, it is not likely to be as reliable as a newer Prius with a much lower odometer reading.
    Here is my list of possible issues, most of these are not catastrophic:
    1. High voltage battery
    2. Air conditioning system, whether compressor, evaporator, condenser
    3. Catalytic converter
    4. Multifunction display
    5. Combination meter
    6. Front struts/rear shocks
    Data Daedalus, Skibob and Raytheeagle like this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    +1;).
    I’d just add the brake actuator to your list(y).
    wnrsm, Skibob and Patrick Wong like this.
