Opinion=Is Hybrid Battery Reconditioning, just a temporary fix?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Jan 14, 2020.
  1. ski.dive
    ski.dive Active Member
    865
    224
    Hutchinson Island,FL. Mt. Snow,VT
    IS IT COST EFFECTIVE???
    1-How long will a ''Hybrid Battery Reconditioning'' last?
    2-How much $ does it cost to have a ''Hybrid Battery Reconditioned''?
    #1 ski.dive, Jan 14, 2020
    ydpplqbd likes this.
  2. SFO
    SFO Senior Member
    5,286
    4,226
    Northern California
    Nothing lasts forever :confused:
  3. ydpplqbd
    ydpplqbd Active Member
    542
    250
    Purchased my 2006 Gen2 with a bad HV battery and bad 12V battery from the prior owner (after they got the more than $4000 estimate for HV battery alone from the local Toyota dealer). I paid $800 for a reconditioned HV battery installed about 5 1/2 months ago. Since getting the reconditioned battery installed, I have put more than 8000 miles on my Gen2. Now HV battery charges nicely.
    IIRC, SOC reported by the Torque Pro app is usually between 62% and about 72% (sometimes goes a bit higher after a long downhill grade - say 75 or 76% after a long downhill grade). Car goes nicely in EV mode at between 25 and 35mph. I am averaging between city and highway driving between 46 and 48mpg (we have had a warmer spell lately and fuel economy has increased a bit but is NOT reflected in the 46 to 48mpg numbers). All battery cells are within 2/10V of each other as reported by the Torque Pro app.
    #3 ydpplqbd, Jan 14, 2020
  4. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
    Of course. Batteries don't last forever. One just needs to define "temporary". ;)
    I wanted at least another year out of a failed battery (threw codes, turtle mode, etc) and got that by replacing the failed module(s) and conditioning it for the next year.
    jerrymildred likes this.
  5. ski.dive
    865
    224
    How much did it cost you???
  6. Tj S
    Tj S Member
    34
    32
    Oceanside, ca
    I've had no luck with reconditioned cells etc. I went and got a new gen3 battery from toyota for $3k and installed myself. Car has been running well for 2 years now with max mpg and no CEL lights and minor battery depletion overnight.
    The only reason I spent so much money, was because I'll take the battery with me to a new car if I have to. All toyotas use same gen 3 battery to 2010.
    SM-G960U ?
  7. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    Is it temporary? Of course. So is a new car.
    Probably, but it depends on the condition of the battery and how good of a job you do.
    See the above answer.
    All it would cost me is parts.
  8. ski.dive
    865
    224
    From all the reading I've done...Many Prius owners, had no luck with reconditioned cells!!!
    For the Gen. 2 Prius models, you can buy a NEW TOYOTA pack that will last at least 10 years for under $2000.
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,783
    2017 Prius c
    And that result is no different than the results obtained in the last 100 years or so for all battery types since they first came into common use.
    There is a "snake oil" solution for almost any problem.
    And there never is a shortage of people willing to buy it.
  10. ydpplqbd
    542
    250
    I paid $800 for my rebuilt battery installed and it appears to be working properly. Especially, now that I learned State of Charge (AKA "SOC") should not exceed 80% ( a gauge on my Torque Pro with Gen2 PID) . Remember, I bought a pig in a poke when I bought my Gen2. As both the 12v and HV batteries were shot. As a result, I had to rely on the Toyota analysis of the problem and their recommendations on fixing the problem. I would never have paid $2000 for a new HV battery for such a car (with so little knowledge of its running ability).
    PS I paid under $1000 for my Gen2. Thus, a $2000 HV battery was a no-go initially.
    PPS If I decide that I am going keep this Prius for the long haul (say another 100k miles) then maybe I would buy a new Toyota HV battery and sell my existing battery for what I have into it.
  11. bisco
    48,987
    it's like an oil change. good for the car regarding longevity.
  12. PriusCamper
    PriusCamper Senior Member
    10,926
    4,427
    Pacific Northwest, USA
    Yes... Exactly... You aren't "fixing" something that's broken... Reconditioning is a basic maintenance requirement for all nickel-based batteries and Toyota decided it was more profitable to design the vehicle to run on only 50% capacity due to a lack of a built in reconditioning system. And think of how much money they've made selling brand new packs because a healthy battery in need of reconditioning maintenance isn't offered as an option? Yet another example of a lack of consumer protection laws...
  13. Aegean
    Aegean Active Member
    423
    184
    Alexandria VA
    I do not think you will find an answer on this since results vary from a few days to few years. I had a battery reconditioned at 160k 8 months ago and now I have 170k and luckily still no codes.
    I paid $580 including reconditioning, 2 trips to my house, loaner battery for 2 weeks and removal and installation of both batteries.
  14. sam spade 2
    7,035
    2,783
    2017 Prius c
    Here we go again with off the wall claims.
    "all" nickel based batteries are NOT the same.
    Things that you learned about NiCad batteries do NOT (generally) apply to other nickel formulas.
