Opinions needed please.
Discussion in 'Gen 3 Prius Main Forum' started by nathenvan, Nov 13, 2019.
  1. nathenvan
    nathenvan Junior Member
    52
    16
    Delaware
    Hi all,
    So back in March of 2017 when the vehicle had 155k I went to the dealer and complained about the rough idle in the morning. Looking at the receipt now I noticed they replaced the EGR Valve, Mod Harness and Gaskets and EGR Cooler. These were all done under a recall that Toyota had issued. My question is, am I safe to assumed that my EGR and cooler are good for now and does not need cleaning at the moment. I would like to avoid it if I do not have to. I did clean out the EGR pipe which was pretty dirty.
    It is a 2010 and I am now at 205k. What do you guys think. TIA.
  2. Mendel Leisk
    41,908
    There's two EGR-related part numbers in your attachment:
    1. 04004-58137 < From Google search, this appears to be just the EGR valve, perhaps with gaskets, to make it a "kit".
    2. 25685-37010 < This is the gasket betwee the EGR cooler and exhaust manifold
    For your info, the EGR cooler part number is 25601-37010, at least the original number.
    I would suspect what they did was to remove the EGR valve/cooler assembly, replace the valve portion only, and also replaced the gasket between cooler and exhaust manifold. They may or may not have cleaned the EGR pipe. I doubt they cleaned the EGR cooler, just knowing how they operate. The intake manifold (with EGR passageways) probably also is untouched.
    Assuming that was just recently, I think you better dive in.
    Reference to @NutzAboutBolts videos, some threads, and info:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    Two or three other videos linked there too, for the full cleaning of the intake manifold, full EGR clean, and Oil Catch Can install.
    Good thread:
    EGR &amp; Intake Manifold Clean Results | PriusChat
    Another:
    Oil Catch Can, Eliminate that knock! | PriusChat
    Some tools worth having:
    E8 Torx socket (mandatory)
    E6 Torx socket (optional, but good to have, to remove the throttle body studs from intake manifold)
    3/8" ratchet wrench, regular and long handle, flex head, you can never have enough (or 1/2 plus reducer)
    1/4" ratchet wrench, or 3/8" to 1/4" reducer
    Ratchet extensions: you can never have enough
    Long needle nose piers, straight and bent tip
    Ratcheting 12mm box wrench (optional, but makes disconnection of the EGR cooler from exhaust easier)
    Torque wrench (3/8" and 1/4" both good to have)
    Floor jack and safety stands (or ramps): basically some method to raise front, if you need to take underpanel off, which you may need to, both for access and to recover dropped items.
    #2 Mendel Leisk, Nov 13, 2019
    mikey_t, scona, Greenteapri and 2 others like this.
  3. Mendel Leisk
    41,908
    Oh, and that was almost 7 years back.
    Never mind, repair was 2017. Still...
  4. nathenvan
    52
    16
    Delaware
    I was hoping that they did change it but I guess not. Thanks for the advice.
  5. Mendel Leisk
    41,908
    While you're doing the intake manifold would be an opportune time to do an oil catch can install too. There's a link in my post above, a good Priuschat thread, and @NutzAboutBolts has a video on that as well.
    scona and NutzAboutBolts like this.
  6. nathenvan
    52
    16
    Delaware
    Copied thanks
