Optima D51 battery - why elearnaid? Seattle area installers?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cwerdna, Jan 5, 2011.
  1. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Ok, I'm likely going to need to replace the original 12V battery on my Prius (purchased late January 06). I think I want the Optima D51 that people are recommending, but out of curiosity, why are people recommending or linking to elearnaid? Is it because they sell a bundle w/the an adapter kit (that I stumbled across at http://www.elearnaid.com/12vo1topraub.html. If I go to Buy Optima Batteries - Where To Buy An Optima Battery, there seem to be plenty of local dealers that sell Optima batteries (unclear if they have the size I need).
    For kicks, I went to Optima Battery Selector - Car Battery Selector by Optima and selected 2004 and 2006 and Prius didn't even come up as a Toyota model they have a battery for...
    I'm likely going to call my local dealer for a price quote to install a Toyota OEM 12V battery that they supply and see if they're willing to install an Optima w/a kit. I hear the latter isn't likely, so I'm looking for suggestions for a good place to have it done in the Seattle area. (I don't have all the tools nor am I really motivated to spend the time to get the all the tools and DIY.)
    Anyone have experience with Green Car Clinic? At least they're pretty close to me.
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Why?
    The elearnaid kit includes shipping, so there are no nasty surprises where we said $165 but shipping made us wrong.
    No Battery fits the Prius except Toyota's battery. elearnaids kit alters the wiring harness so a battery that 'does not fit' does.
    All the folks who ordered from elearnaid liked the process, that encourages repeat business.
    If you find an installer, Hobbit has an illustrated how to for them.
    Prius 12V swap
  3. richard schumacher
    7,663
    1,038
    United States
    Their kit, plus their very good instructions, plus their very good service. They appear quite consistent in fully charging the battery immediately before shipment. Car dealers sometimes let batteries sit around long enough to start sulphating before installation.
    The OEM battery lists at $140 and is a little easier to install. If a dealer will install a new OEM battery for less than $200 that's certainly the easiest solution.
  4. saechaka
    saechaka Member
    225
    I went to Moss Alley Home Page and labor cost was $86 after tax. It came out cheaper to replace the original w/the optima than going through the dealer who wanted about $265 before tax to replace it with a stock battery.
  5. sambojoho
    sambojoho Proud conservative
    92
    23
    Ohio
    Just FYI, I replaced my 06 prius 12V battery last weekend in less than 30 minutes with a OEM replacement from the dealer for $138. Only tools I needed was a socket wrench with a 10mm and 12 mm socket. Wasn't a difficult job at all, anyone that can use a socket wrench and unplug a couple wire harnesses can tackle this job.
  6. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    I received my D51 battery and kit today.
    Anyone else w/Seattle area (preferably on the Eastside) installer recommendations? Moss Alley isn't that convenient for me to go to. Anyone deal with Green Car Clinic that I asked about before?
    My Toyota dealer is unwilling to install any aftermarket parts. Apparently, it's a policy of that chain now. :( It wasn't the case when I asked them a month or two ago.
    I'd rather not DIY as I don't have all the tools they call for (it's more a bit more than just a socket wrench and 1 sockets, per Toyota Prius 12 Volt Auxiliary Battery with install kit for 2004 - 10).
    I take my Z to Autologic Quality Auto Repair Bellevue for work and trust them, but I'm not sure how much Prius experience they have.
  7. Patrick Wong
    18,200
    6,472
    You really don't need "Prius experience" to change a 12V battery...
  8. richard schumacher
    7,663
    1,038
    United States
    ...just follow the instructions and don't drop any bolts :_>
  9. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Hook the ground wire up last... it's safer!
  10. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Well, looking at the instructions, it seems I (or the installer) need to muck w/the ventilation duct, change terminals and need a few tools I don't have. I've changed car batteries from regular cars before haven't had all these extra steps before besides having a black box obstructing the battery.
    Ha... Ok, I'll re-examine whether I want to DIY.
    Unfortunately, we're not supposed to work on our cars in my apartment complex either so I'm going to have to drive it somewhere else to do it. I guess a hardware or auto parts store is where I'll be. :)
  11. Patrick Wong
    18,200
    6,472
    Regarding the brake power supply: just remove the bolts that secure it to the hatch floor, and move it aside. You don't even have to remove the wiring harness connector.
    Buy whatever tools you will need. This is really not that big of a deal and the tools will be useful for other purposes in the future.
  12. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Look at this as an opportunity/excuse to get some new tools to play with! :)
  13. richard schumacher
    7,663
    1,038
    United States
    It may take a lot of hand strength or a vise to take apart the positive terminal assembly. It was about at the limit of possibility for me without a vise to help hold it.
  14. Patrick Wong
    18,200
    6,472
    Agree; I had a similar experience when installing a Panasonic battery in my 2001. Amazing how tight that positive terminal nut can be.
  15. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Ok. I did it myself today. It took me ~1.5 hours.
    Yes, that darn positive terminal assembly was on tight. I couldn't get it off w/the ratchet handle I had. Fortunately, I was able to borrow a longer one for more leverage from the auto parts store I parked in front of.
    I ran into some space issues trying to unbolt the negative terminal from the original battery. I unbolted the cable from the body instead.
    I didn't know how long an extension I'd need but fortunately, the 6" I bought was enough. I'll probably drop elearnaid a note about that. Their negative cable was also a bit longer than needed.
    When I looked in the back of the Gen III, I recall it looked a lot easier since there were fewer things in the way.
  16. Rest
    Rest Active Member
    1,210
    53
    CA
    My 2007 Prius has been suffering a dead 12 volt battery off and on for around a year now. I have not been driving it much and usually just have to hook up my battery charger to get it started, if it's dead. Well yesterday this no longer worked and I had to actually connect the charter directly to the battery in the back, disconnecting the battery from the car's electronics. Once I got the battery fully charged, I reconnected everything and discovered the master warning light was on. I also lost my trip mileages and data for the current tank of fuel. I couldn't find a way to reset the master warning light and my scan gauge wasn't showing any codes, but after a few minutes it reset itself. I then drove the car for about an hour and everything seemed fine.
    Since I know the battery will just go dead in a week if the car is not driven enough, I decided it was time to order the e Learn Aid kit. I feel going with the Optima Yellow Top is the better option and this kit will make the install much easier. Although, I can handle replacing a car battery.
    Since I'm always looking for the best deal I was going to purchase the Optima on Amazon for $155 shipped with no state tax, then buy the installation kit from e Learn Aid for $15. But it turned out to be less expensive buying the whole thing from e Learn Aid with tax, thanks to their sale price and free shipping.
  17. Rest
    Rest Active Member
    1,210
    53
    CA
    I am beginning to wonder about e Learn Aid. I ordered my 2007 Prius battery kit on Saturday and here it is Tuesday without a word from them. So I called to inquire about my order and they said it should arrive to me today. But nothing has shown up as of yet.
    I find it odd that they didn't send me tracking info or even notify me that my order had shipped. This is surprising because forum members say good things about this company, so hopefully I am just experiencing an anomaly.
    UPDATE: The battery and kit just arrived! There is no handle on the battery or a lead post connected to the cable, as shown in some member installations. I assume e Learn Aid changed things for whatever reason.
    E Learn Aid just raised the price of their 2004-2009 Prius Optima battery & installation kit from $165 to $180. The installation kit alone went up from $15 to $20.
  18. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Mine showed up very quickly. I ordered on 2/7, got a shipped to me confirmation email on 2/8 and I believe it arrived on 2/10. Mine also had no handle. I'm not sure what you mean by "a lead post connected to the cable". Mine was basically as depicted at http://ep.yimg.com/ca/I/elearnaid_2142_12026078.
    I'm glad I got in before the price went up.
  19. Rest
    Rest Active Member
    1,210
    53
    CA
    My cable and connector looks like that also. It's more like the OEM negative battery connector.
    In the past some members had received a negative post connector that was made of lead, like the separate positive connector. Here are some pictures of them:
    Prius Optima Aux
    Prius 12V swap
  20. MJFrog
    MJFrog Active Member
    780
    266
    NE Oklahoma
    2018 Nissan LEAF
    Yeah, that's about how long it took me the first time (on wife's car). When I did mine it was a little quicker, but I found about 1 1/2" of water in the bottom of the battery well (clean, not rusty or dirty) and it took time to remove that. Still trying to figure out where it came from.
    You did right...the instructions say to do it that way...and tape the loose end to avoid any short.
    There, ya see, it wasn't all that bad!
    [edit]There were several times though, that I wished I was left-handed instead of right. It would have been a lot easier![/edit]
