Optimal Driving Mode Select and EV/HV drive mode combo?
Discussion in 'Prime Fuel Economy & EV Range' started by IABoy987, May 20, 2020.
Tags:
  1. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
    I looked through several pages of this forum but did not see quite a specific answer.
    Wife and I read and re-read the manuals for Driving Mode Select (normal,power mode, eco driving mode) and EV/HV drive mode (EV mode within/not in a box, EV auto), and not sure what is optimal settings. In Iowa its mostly "flat land driving" as such no serious hills or mountains to climb. We know that we don't need power mode as there is just two people in car and we don't pass everything on the road, driving nice and easy at speed, in no hurry.
    We concluded that ECO drive mode and EV auto should be best combo (let those $$$ computers figure it out ;)). What have you experienced Prime owners found to be the best setting combo? :)
    Tips likes this.
    52,747
    there is no one best setting, it's multi factorial. and tbh, there's no big difference for any of them.
    ev keeps you in ev when you want it to.
    ev auto lets the computer decide.
    hv runs the engine more an little ev.
    eco is to help people improve their mpgs by remapping the throttle sensor, but uses the same power by pushing harder the power mode.
    there is no more power available in power mode, it just comes faster with a lighter touch of the pedal.
    if your main concern is saving a few sheckles, compare the cost of gas and electricity, and use the cheaper fuel.
    MTN and IABoy987 like this.
  3. schja01
    schja01 Senior Member
    1,867
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    For me EV Auto is of little value. It basically runs EV until the battery depletes and then goes HV. This to me is what leaving it in EV initially does. To each their own.
    Tightwad77, jerrymildred and IABoy987 like this.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    Unless I am driving on a busy city highway, Eco mode works fine for me. I switch EV and HV modes back and force to improve EV efficiency unless my trip is short enough to finish all EV. As stated, EV Auto has no value in my driving situation.
    Tightwad77 and IABoy987 like this.
  5. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    I haven’t used EV Auto much (in fact, I don’t think I’ve ever used it in the 3 years we’ve our Prime!), but my *impression* is that it works much like the original Prius Plug-In: it drives on EV all the time, except that it kicks in the engine to assist the motors when you accelerate hard, to keep from expending the battery charge quite so quickly.
    I’d say the best way to drive would be, basically, just drive; it does a great job of figuring out the best usage on its own. However, if you want to get more involved in it, I’d suggest: If you can take your trip entirely on electric, then do so. If not, then stay on electric at low speeds, and kick in HV once you’re mostly cruising.
    The mode I *wish* it had instead of EV Auto is what might perhaps be called “HV Auto“: In this hypothetical mode, it would behave exactly as it does in HV mode, except that it imposes an absolute lower limit on instantaneous MPG. That is, it drives in plain HV, except that if at any instant in time it needs to add power from the ICE, and if doing so would drop your instantaneous MPG below, say, 50MPG, it sources that power from the battery instead.
    #5 mr88cet, May 20, 2020
  6. eatriceyo
    eatriceyo Member
    45
    33
    Honolulu
    leave the car in normal mode and use ev driving when you're in the city. definitely use cruise control for long drives to maximize mpg.
    Tightwad77 and mr88cet like this.
  7. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    If you really want to minimize fuel use, and your trips are regularly long enough that you can't make it in EV mode, using HV mode for acceleration and hills and EV for cruising and downhill will maximize your overall efficiency.
    Tightwad77 and Raytheeagle like this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    +1;).
    That's what I do everyday for my 38 mile each way trip to work:).
    Over 23k miles (which includes longer trips) I've averaged 139.7 mpg. Blend the modes to maximize efficiency(y).
    Tightwad77 likes this.
  9. PiPLosAngeles
    1,551
    724
    It took me a year of careful trial and error to confirm that is the best overall strategy. Now my problem is that if I use HV for every start and every hill I will return home with significant amount of EV remaining, which is suboptimal. Before all the lockdowns I was experimenting with only using HV when accelerating uphill or driving uphill.
    EDIT - My pipe dream for a plug-in is to have a programmable EV AUTO mode, where I can set the switchover point based on engine load. Even if they dummied it up and just let you set some kind of bias towards EV or HV (like setting an arbitrary number from 1 to 10, with 1 being staying in EV under all conditions and 10 being staying in HV under all conditions), it would greatly improve efficiency.
    #9 PiPLosAngeles, Jun 13, 2020
    Tips and Raytheeagle like this.
  10. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    I don't do it for every incline, but I make sure at each end of the work trip I finish at 1% or less;).
    So the steepest inclines get HV and the more gradual ones get EV mode:).
    My charging at work is free, so I ensure that I get there near empty and since I work kore than 8 hours, leave full(y).
  11. Salamander_King
    11,024
    8,977
    New England
    For optimal overall mpg using EV and HV mixed and switched, the daily drive has to be substantially longer than the EV range. I think 70-80miles is the best distance to get most out of and EV (high miles/kWh) and HV (high mpg). With my commuting of 36 miles round trip and no charging opportunity at work, I can make almost home all on EV during summer. If I use HV for the portion of this commute on the start-up, accelerate, and uphill, I can get extremely good EV efficiency, but will end up not using all of the charge and substantially lower mpg than just driving EV until it depletes to zero.
  12. Tideland Prius
    16,665
    My daily drive is within EV range so it’s Eco mode with Eco Heat/Cool and S-Flow Auto and EV Drive Mode.
    My area has free public charging so if I need to extend my range, I can top off within an hour while I do errands. Less so now given the current conditions and the fact I have a full tank of gas so I’m not as picky when the engine comes on.
    jerrymildred likes this.
  13. NSXT
    NSXT Active Member
    137
    119
    Toronto, Canada
    2018 Prius Prime
    To maximize EV I use the following flip combo:
    EV = local, downhill
    HV = highway, uphill
    If wife drives, just drive and do nothing :ROFLMAO:
    Tightwad77, douglasjre and benagi like this.
  14. schja01
    1,867
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    Which is probably how Toyota engineers designed the car to be driven.
    Tightwad77, Tips and jerrymildred like this.
  15. Tips
    Tips Member
    128
    66
    Grand Forks, B.C. Canada
    2020 Prius Prime
    I've started using ev auto in eco mode . The Prime in ev auto decides the mode. My last trip 110 kilometers there and back with two passes over 5200 hundred ft.. The trip was from Grand Forks, BC. too Trail, BC and return! I started with 30% charge (not on the ball) and started with hv mode to warm the ice up! After five min. I hit the ev auto twice. On the 15kilo hill down too Trail I switched too b mode and managed too get 40% full pack. On the return trip ( same route in reverse) I kept the car in ev auto! When I arrived home I had 10% ev! My trip was a total off 220 kilometers and the fe was 3.1 kil per 100 kilometers or 75 mpg .
    Tideland Prius likes this.
  16. Tips
    Tips Member
    128
    66
    2020 Prius Prime
    Probably the best thing you can do is to keep your speed at 60 mph in the flat country and watch the high mpg you can get. It will surprise you. This car can be amazing if you smell the and enjoy the ride!
  17. samlarson
    samlarson New Member
    Clifford
    Yeah, that what I usually do
    Tips likes this.
