Optimal speed for best mpg??
Discussion in 'Gen 2 Prius Fuel Economy' started by smtrader, Apr 13, 2005.
  1. smtrader
    smtrader Member
    105
    Cerritos, CA
    I've noticed that I get the best mileage (52+) when I've been driving between 70-75, and slightly less between 65-70...this is while commuting back/forth to work in SouthernCal freeway.
    Does anyone have any thoughts about optimal range fo speed for best mileage (given all the other factors that affect mileage)?
    Brian
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    most definitely. with all things being equal and wind resistance increasing as speed goes up, then the slower you go, the better
  3. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    What does this have to do with "Appearance Modifications"?
  4. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    what does a question about "appearance modifications"
    have to do with a post in the "fuel economy" forum?
  5. DanP
    DanP Member
    256
    <div class='quotetop'>QUOTE(smtrader\";p=\"81001)</div>
    If I'm reading you correctly, you're saying you get better mileage doing 70-75 than you do going 65-70. If you think that, then you're mistaken. There is no way you're going to get better fuel economy by going faster (at least not at the speeds you're talking about). The best fuel economy is achieved from about 35-55 mph.
  6. wb9tyj
    wb9tyj 2017 Prius Prime Advanced
    389
    94
    Indiana and Nevada
    i have found 2 speeds that are maximal for fuel economy...after doing the calculas and plugging in all the parameters...the following numbers are...in the city the maximal fuel economy occurs at 38mph and on the highway it occurrs at 62mph...these numbers will ,of course, vary, given wind direction and speed, however, given constant values...these numbers are pretty close...
  7. IsrAmeriPrius
    4,333
    Southern California
    <div class='quotetop'>QUOTE(DaveinOlyWA\";p=\"81024)</div>
    Obviously, a moderator or an administrator of PriusChat has moved this thread from the "Appearance Modifications" forum to the "Fuel Economy" forum since I posted this question. This thread originated in the "Appearance Modifications" forum.
  8. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ahhh sooo!!
    your question fell on alert ears then
  9. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
    My best mileage occurs between 40 and 60 mph but more specifically at around 50 mph.
    The best mileage possible however is achieved at around 38. I saw the screen on another group where the guy drove almost a thousand miles at a 35 mph average and got 967 miles at 87.6 MPG. That number might be off by a fraction. I can't do that in my driving but I have tested various speeds and found that above 50 mph, mileage drops off about one MPG for every one mph in increased speed. If 70 mph is getting you your best mileage, I can only guess that the rest of your driving involves lots of stopping and starting. Also cruise control will not achive as good of a mileage figure as a conscious driver; because, it is far to aggressive with the throttle and the regen.
  10. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    The best fuel economy I have seen to date occurred over the last weekend when I went for a 3 hour drive. Due to concern over possible flooding from the heavy winter snow that is melting, the road crews were clearing out all the culverts.
    This required closures to one lane on sections of the Trans Canada with 70 km/h (Around 42 MPH) speed limits. My MFD claimed an average of 3.6 L/100km at that speed, which lasted around 20km.
    78 MPG Imperial Gallon or around 65 MPG US gallon.
    I will agree that going *too* slow will kill the fuel economy as the ICE will cycle on and off. But there must be a "sweet spot" for highway speed that maximizes fuel economy.
    My daily commute has around 5km at 70 km/h, 3 lights, and the MFD will claim an average of 3.8-4.2 L/100km. It really helps having the temps back up to +15 to +20C. That -40 was killing me.
    OTOH at 110 km/h and no wind, the MFD will claim 4.8 L/100km or 58 MPG Imperial gallon. I would think that given how air drag can express almost a logarithmic change with increase in velocity, there is no way a car will get better fuel economy at 75 MPH instead of 45 MPH, unless there is something odd with the gearing.
  11. smtrader
    smtrader Member
    105
    Cerritos, CA
    Yea, I guess I should've been more specific with my initial question: I was wondering if there was an optimal speed for HIGHWAY (non-stop) driving, such as when I'm commuting to work via freeway in SoCal. Obviously, I can't drive 35, or even 50, on these freeways!
    I'll check again, but would like to hear from others with warm climates! (sorry about the cold stuff)
    And...sorry to offend anyone about the post being in the wrong forum...I just clicked on New Topic after a reply and didn't even notice the forum I was in!
    Brian
  12. tim_in_jax
    tim_in_jax New Member
    Jacksonville, Florida
    I am glad that someone else made the observation that I have noticed concerning cruise control. I thought I was going crazy because everyone recommends using cruise control for the highway but I have always been able to achive better results operating manually ( maybe not a consistant ).
    Now on to the direct topic. My daily commute is 67 miles one way. 59 miles is highway traffic. I normally get the best results when I stay within the 68-72 mph range. any faster and I take a severe MPG hit. Any slower and I take a big safety and ego hit driving that slow on a major interstate
  13. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    cruise control is good for a lot of reasons. but it does over-react to small hills. when i use it, i am constantly adjusting it so its not to maintain a constant speed. i have learned where and how cruise control will work and learned to adjust it accordingly. this will take time and soon you will instinctively know how to adjust it even for areas you are unfamiliar with.
    as to driving slower than 68, that has more to do with the age of the driver than it has to do with driving conditions.
  14. kinghuang
    kinghuang Member
    119
    Calgary, AB, Canada
    I find I get the best mpg during the main stretch of my morning commute where I'm usually around 80 to 85 km/h for about 10 km. The MFD always shows gas consumption between 2.3 to 2.8 L/100 km. It's my favorite part of the morning. :)
  15. 200Volts
    200Volts Member
    429
    43
    Northern CA
    MAGIC SPEEDS
    The following are for level ground, nominal battery charge:
    31 mph- above this the ICE MUST be used to accelerate
    41 mph- above this the ICE will always be on
    54 mph-most PRODUCTIVE speed where mph=mpg
    So to max out mileage:
    Learn to accelerate to speed, lift off the gas for 1 second, then cruise. This will allow MG cruising when possible.
    Go 40 mph max around town.
    Go 55-65 mph on the freeway. When going up small hills-overpasses slow about 3-5mph then accelerate on the downside back to cruising speed.
    When slowing from highway speeds, Coast down to 40 mph-then cruise if needed before slowing more.
    Use brakes as little as possible, if needed- brake at 2 mph/second deceleration-this produces maximum energy regeneration.
    Don't drive when it's cold, mileage is worse in the winter then the summer.
  16. gschoen
    gschoen Member
    343
    Chicago/Wrigleyville
    2014 Prius Plug-in
    Is 2MPH/sec a fairly light touch on the brake? I always wondered exactly where regen braking works best, and figured long and slow would help to keep heat produced down. Plus batteries in general like to take a charage more gradually so I am figured Prius works the same. Too bad there's no "regen efficiency" screen that displays instead of 99.9MPG.
  17. 200Volts
    200Volts Member
    429
    43
    Northern CA
    My 2mph/sec is light to moderate braking. You can gauge this by taking 30 seconds to stop from 60 mph, etc..
    This number is from another post on PriusChat where someone(?) hooked into the ECU bus and measured the current being recovered at different decelerations.
  18. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    I generally find a "sweet spot" at 41 to 51 mph with cruise control and get 55 to 67 mpg at that speed (moderate air temperatures, only a few traffic lights, old freeway that is now a parallel expressway, offers 12 miles of continuous, low traffic travel). Roadway is gently rolling, but mostly level.
    I get optimum fuel economy and 7+ green bars on the battery.
  19. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i notice that mileage seems best at 25-35 mph, then seems to take a dip at just above 40 mph, but seems to get better at 45-55 mph... seems strange and probably not an accurate observation since im only going by estimates based on real time readings of the MFD
  20. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    all right! i always wanted an excuse to not go to work in the winter...
    'sorry boss, i won't be in today due to excessively low mpg.'
    :wink:
