Optimizing fuel economy with EGR
Discussion in 'Gen 3 Prius Technical Discussion' started by usbseawolf2000, Jan 24, 2013.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,996
    Fort Lee, NJ
    I found some interesting charts/graphs in SAE 2009-01-1061 paper and I thought it would be beneficial to squeeze out the most efficiency of our GenIII Prius (including PiP) and perhaps Prius v and CT200h (basically the same engine). If you think they are helpful and would like to read the rest, support it and purchase it like I did.
    I made it a background pic in Torque app so I can glance at it by switching to an empty gauge page. EGR and Timing Advanced are available in Torque as a gauge so I can monitor it.
    For more info about BSFC based on the rpm and engine torque, see this thread.
    Sample text from the SAE paper:
    Figure 12 shows fuel consumption rates and pumping-loss during low load conditions plotted against the EGR rate and VVT-i angles. As VVT-i was advanced to an early closing timing for the intake valve, the pumping loss supressed by the effect of Atkinson cycle increased at whole EGR rates. Because pumping loss mainly affects low load conditions, in this situation, increasing the EGR rate is better to improve the fuel efficiency rather than increasing effective compression ratio by advancing VVT-i.​
    Figure 13 shows fuel consumption rates and spark timing during high load conditions plotted against the EGR rate and VVT-i angles. In high load conditions, the throttle is almost fully open, so the ratio of pumping loss is reducing. In this situation, advancing the VVT-i angles increases the effective compression ratio. This makes it advantageous to increase indicated work, however, spark timing could not be advanced due to the knocking on the Atkinson cycle with 13.0 compression ratio. Then by introducing cooled EGR gas, the reduction of the combustion temperature and advanced spark timing could be improved fuel efficiency.​
  2. edwardob
    edwardob Member
    227
    33
    ireland
    what does this mean for the average driver? as far as driving habits are concerned??
    is there a scanguage feature that can be used?
    i ask because all this tech is over my head!11
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Welcome to the Future, we're glad you made it!
    No the Scan Gauge while they may be able to display the appropriate X Gauges, a small tablet running Torque will be needed to get a easy visual reference!
  4. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Excuse me, but isn't it: Hello, we're glad you made it. Welcome to the future!
    We're all bozos on this bus.
    KK6PD likes this.
  5. usbseawolf2000
    14,487
    2,996
    Fort Lee, NJ
    I think SGII has IGN and EGR.
    I am guessing Ignition timing advance is the same as VVT-i angle. So, using those two, you'll have x and y axis to plot it on the low or high load graphs. The goal is to stay in the blue region (good fuel consumption area).
    edwardob and NortTexSalv04Prius like this.
  6. edwardob
    edwardob Member
    227
    33
    ireland
    aaah! now were getting somewhere
    i see ign but not egr
    ign then seem to be steady 10-20.......egr is about 22 [looking for scanguage equal???]
  7. edwardob
    edwardob Member
    227
    33
    ireland
    anyway from my looking at graphs .....the car is hardly moving...1200rpm@80nm about 56% lod whereas from myreading on this site 85% lod is the most efficient
