options for switching off rear dome light?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Perkolator, Jan 22, 2014.
  1. Perkolator
    Perkolator Junior Member
    33
    Sacramento, CA
    On our 2013 Prius II, it seems there are no options to switch off the rear dome light for the 2nd row seating without affecting the front -- the rear dome switch is only 2-positions (ON or ON w/doors) instead of 3 like most dome lights are (like the front). The problem for us is that we have a baby that rides in the back and when baby is asleep and we come home guess what happens... Would love to find a simple solution to this little annoyance.
    Does anyone know of a dome light replacement option for me that won't break the bank? I figure the easiest way is to swap out the housing to one with a 3-position switch. Do the higher model Prius come with this option?
  2. peterjmc
    917
    189
    Clarksburg, MD
    I was thinking about fabbing a three position or separate two position switch and mount it up front. There are times when I only want the rear lights on for my two year old and not the ones up front at the same time.
  3. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
  4. Burna J
    1,067
    3,336
    53
    Long Beach, CA.
    Have you tried to put the switch in the middle? Give it a try. Works for me....
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Black tape is a simple solution.
    When I was a younger, I "tinted" my dome lights by adding a piece of colored cellophane wrapping paper inside the cover. It reduced the light output to an agreeable level.
    iPhone ?
  6. bathala
    bathala Member
    128
    30
    Area 52
    put a hat on the baby.
  7. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Remove the bulb?
    bathala likes this.
  8. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    That would be the easiest solution.
  9. Perkolator
    33
    Sacramento, CA
    problem with eliminating the rear light is we need it for getting all the other junk out once child is removed.
  10. xliderider
    8,056
    3,223
    Honolulu, HI
    Have you tried moving the switch to the "middle" position as Burna J suggested?
    SCH-I535
  11. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    I can confirm this works.
