Options to Replace Hybrid Battery
Discussion in 'Gen 3 Prius Main Forum' started by 15persona, Apr 5, 2025.
  1. 15persona
    15persona Junior Member
    Plano, TX
    My 2015 Persona (185k) just received the code which needs not be named. I have been looking into what my options are to get it fixed and here is what I have found so far
    OEM Toyota (I swap the battery units myself) - $2500
    Green Bean (all new cells, they install)- $2000
    Green Bean (remanufactured, they install) - $1250
    My questions:
    How much time and cost of materials (new battery cells) to fix my battery myself? I’d probably replace all of the cells if I go this route.
    Are there reputable companies that will sell you a remanufactured battery for less than the $1250 green bean charges? It doesn’t seem like that bad of a deal since it includes install and it has a warranty. I am just trying to identify my options so I can decide how to proceed with running this car into the ground.
    thanks everyone
  2. audiodave
    audiodave Active Member
    798
    269
    US
    You may be able to just change some cells at that age.
  3. ASRDogman
    ASRDogman Senior Member
    7,108
    3,713
    Toyota hybrid battery upgrade pack– NexPower Energy
    51,012
    at $2,500. for the oem, grab it before it's gone. that's the best price i've seen in awhile.
    swapping it out is fairly simple. just be careful and methodical.
    Mr. F, MAX2 and Mendel Leisk like this.
  5. 15persona
    Plano, TX
    Leaning towards this option. Do you recommend any particular posts/videos about how to do it? Also how do I know how many battery cells I need without taking it apart and testing them individually? Thanks
  6. DirkAshburn
    DirkAshburn Member
    118
    47
    Virginia
    IMHO I'd just replace it, eventually they are going to fail. The best I have seen is this one. It's not the same battery as OEM, but the process is very similar.
  7. audiodave
    798
    269
    US
    Get the Dr Prius app and a 0B2 Bluetooth adapter. You can see what paired blocks are doing and how even they all are together. Getting a look at how they all function together is the first step.
  8. 15persona
    Plano, TX
    Update I wasted 2 months with no car and I give up. I meticulously tested each battery put my whole pack together. I had a great battery pack and then one of the studs broke when I went to torque everything down due to my own mistake. I do not have the time or energy to start over on this having already wasted 2 months. I am going to pay someone to replace it because I am missing out on overtime every day I don’t have a car and the repair would have paid for itself at this point. If anyone has recommendations for reputable companies that replace the hybrid battery with NEW cells I would love to hear them. Not thrilled with green beans customer service so far.
  9. bisco
    51,012
  10. DirkAshburn
    DirkAshburn Member
    118
    47
    Virginia
    What stud was broke, one on the pack? Can you just get a replacement from a junk yard? Seems like you are >.< close to having it wrapped up and done.
  11. ASRDogman
    7,108
    3,713
    Don't feel too bad, you are not the only one that has done this...
    Toyota hybrid battery upgrade pack&ndash; NexPower Energy
