ordered 4 Denso coil packs from Amazon, two different #’s
Discussion in 'Gen 2 Prius Technical Discussion' started by prius_newb66, Sep 7, 2023.
  1. prius_newb66
    prius_newb66 Junior Member
    62
    17
    Chicago
    From the same seller so I do find this a bit odd but two of them came in sealed Denso boxes and have the number on top sticker “673-1306” and two of them came in just clear plastic bags with the number on the top sticker “099700-2550”
    All of them have the ID number “10R-034811” stamped on the side and are visually completely identical.
    I’m guessing two of them just have deprecated part #’s but was curious if anyone had an idea.
  2. dolj
    dolj Senior Member
    8,553
    4,344
    Wellington, New Zealand
    They are all likely counterfeits, even the ones that came in Denso boxes. Seen the same with counterfeit Toyota parts in Toyota boxes.
  3. Leadfoot J. McCoalroller
    8,143
    7,644
    Pennsylvania
    2018 Prius c
    Be careful, Amazon and eBay are both completely flooded with counterfeit ignition parts.
    Honestly I'd just return those while you can, and go get real ones from a local distributor.
    I buy a lot of stuff from Amazon, I like them in general. But I no longer shop there for most auto parts and especially not auto electric/ignition parts. Just too many fakes and ripoffs.
  4. Tombukt2
    Tombukt2 Senior Member
    13,384
    2,408
    Durham NC
    My coils for my generation 2 and 3 are cheaper than that look different than that and I've had no problems in 3 years and I would have no problems buying them again unlike the inverter water pump for the generation too that fails overnight the coils made by the counterfeit people don't seem to be actually too too bad so I probably wouldn't worry about it too much If I put them on and they're working and they're the gray plastic sealed up units what kind of like you took off the vehicle I'd let them rip not that difficult to change etc there is a new company out that makes these things I can't think of the name of the people they are selling on Amazon they seem to be a pretty good manufacturer there's stuff looks really nice why people spend money to make things look nice that are buried inside of a dark smelly oily engine is beyond my understanding I don't need my coils to look like museum pieces It's ridiculous
  5. bisco
    52,372
    i read today that airlines are being flooded with counterfeit parts, despite the strictness of the supply program.
  6. prius_newb66
    62
    17
    Chicago
    What is your reasoning for this belief? Have these fears been confirmed in the past? How can it be determined that these are counterfeit, how was it confirmed in the situation you’re talking about?
  7. prius_newb66
    62
    17
    Chicago
    Is there more information about this? Have there been investigations that have shown Amazon sourced ignition parts to be often counterfeit?
  8. bisco
    52,372
    just reports from members here who got scammed
  9. Leadfoot J. McCoalroller
    8,143
    7,644
    Pennsylvania
    2018 Prius c
    Tons, if you bother to google for it.
    Of note for your situation: Denso doesn't list Amazon as an authorized reseller of their stuff. Then again, I bet Amazon wasn't the seller: probably one of the shady "marketplace" sellers that also isn't a recognized reseller.
    EDIT:
    Adding, Denso went to the trouble of publishing a PDF to help consumers figure out if they had genuine spark plugs. They wouldn't go to all that trouble if there wasn't a problem eating up their sales.
    They don't seem to have done a PDF for coils yet, but... think it over.
    #9 Leadfoot J. McCoalroller, Sep 9, 2023
    ANDRAS RIMELY likes this.
  10. prius_newb66
    62
    17
    Chicago
    How do you even tell that they are counterfeit though? These look exactly like factory Densos.
  11. bisco
    52,372
    that's the problem, no one has ever been able to tell. even the boxes look oem.
    the trouble comes after installation. they work for a short time, then go downhill quickly. even parts like the steering wheel spiral cable might work up to a year, then quit after all that work.
    one giveawy is usually the price, luring in unsuspecting buyers.
    idk how it was first detected, but it's pretty well known and commonplace. maybe it started during covid parts shortages, but it is happening in many industries today.
  12. Leadfoot J. McCoalroller
    8,143
    7,644
    Pennsylvania
    2018 Prius c
    It is probably worth mentioning that I have successfully used counterfeit coil packs in another car we had, sort of.
    The genuine Hyundai coils ran about 8 years. The counterfeits worked between one and two years. They both failed the same way: worked perfect one day, total dud the next.
    The counterfeit coils were cheap and very easy to swap on that car. It really just came down to the aggravation of the car dropping into "3 cylinder mode" as often as it did vs. the real deal parts.
    So it's not like the counterfeits are useless, you just need to decide on your own balance of what you spend on them vs. how often you need to deal with one failing.
  13. prius_newb66
    62
    17
    Chicago
    So, these were about $70 each, there are coils for the Prius going for $25 each, I understand $70 is cheaper than the $150ish price on the dealer website but they weren’t rock bottom prices.
    I read that a way (maybe) to determine if they might be fake is to measure resistance between the pins and see if all 4 are same. Theory I guess is that OEM will all be very similar between each other, fake might have more variation.
  14. Leadfoot J. McCoalroller
    8,143
    7,644
    Pennsylvania
    2018 Prius c
    Compare to the prices at Denso's authorized distributors.
  15. pasadena_commut
    pasadena_commut Senior Member
    2,827
    843
    Southern California
    Rockauto lists a large range of coils for the Prius, including a Denso part for $55.79. There is a note on the Denso part stating that Denso makes the OEM part. The Denso is the most expensive coil listed, but only by a little bit over other reputable brands. In this case I would probably just buy the Densos since the price isn't outrageous and Denso makes good parts. Coming from Rockauto it is highly unlikely that any of these parts are counterfeit. If they were out of the Densos for some reason there are coils from NGK, Delphi, and Hitachi, all of which should also be of good quality, and they are almost the same price.
    prius_newb66 likes this.
