original tread depth?
Discussion in 'Gen 3 Prius Main Forum' started by lenjack, Jun 8, 2010.
  1. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Anyone know the original tire tread depth on the standard Yokohama Avid's that come with the car. none of the spec sheets at Yokohama or Tire Rack websites shows it
  2. silentak1
    silentak1 Since 2005
    893
    28
    LA
    I'm guessing 10/32nds (OEM S33D)
    Interesting how TR and Yokohama don't have the thread depth listed, but the S33B (diff thread pattern though) has 10/32nd, but that's usually the standard thread depth on new tires.
  3. lenjack
    804
    114
    Pennsylvania USA
    That would have been my guess. Strangely, every other tire has this listed.
  4. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    I also aware that recently tires besides OEM also have reduced tread depth to 10/32".
    Back in the 80', tread depth are anywhere from 13/32" to 11/32".
  5. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
  6. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Anyone that has actually measured the original tread depth on the Yokohama Avid S33 D? I am interested in finding out as well. I called a couple of stores in town and they said they are at 10/32 but when I went to check they had looked at an Yokohama Avid tire different from the S33 D and they don't have the S33 D in stock.
  7. srivenkat
    596
    93
    IL
    Just called Yokohama USA Consumer Affairs at the number listed here:
    Yokohama Tire
    and the representative told me the original tread depth is actually 11/32. The tires on my Prius have ~ 21,000 almost exclusively highway miles and the tread depth reading is 6.5/32. Which translates to 4,666 miles for every 1/32 which means one should see about 42,000 miles out of the tires if driven on highway exclusively.
  8. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
  9. Den49
    Den49 Member
    498
    268
    Maryland
    I did measure the tread depth of the original new Yokohama Avid S33D tires and it was 10/32". I always measure the tread depth of the tires and the PH of the coolant on my new cars at purchase to establish a baseline.
