Our fuel tanks in Australia
Discussion in 'International Owners' started by fgray30, Jul 30, 2006.
  1. fgray30
    fgray30 New Member
    17
    Do we have the same bladder system that the U.S. guys have or a more conventional tank?
    For those who try and fill up the tank as much as possible, what technique do you use? I ask because last time I tried to fill the tank to brimming (where you can actually see the fuel at the top of the filler), I could not do it. It seemed to simply keep swallowing more fuel and I eventually gave up. I put the nozzle on the lip of the filler so I can see the fuel actually flowing in.
    I could easily get the fuel to brim at the top in my Lexus.
    I usually fill up a few km after the last pip on the guage starts blinking. Averaging around 1,100km/tank. Tank averages range from 3.9 to about 4.2 l/100km.
  2. Cheap!
    Cheap! New Member
    1,157
    Greetings Fgray30,
    Yes my Prius here in the U.S. has a bladder system too. I have tried to fill it to brimming too but I have given up trying to do this. Twice I have had fuel spat back at me and once I have read that there might be some pressure regulator in the top of the bladder that could be broken if you overfill too much, so I gave up trying all together.
    I've just learned to be happy with my fuel economy instead of how far I can go on a single tank.
  3. fgray30
    fgray30 New Member
    17
    <div class='quotetop'>QUOTE(Cheap! @ Jul 30 2006, 10:58 AM) [snapback]294611[/snapback]</div>
    Hey thanks for the reply.
    It's not really about going as far as I can on a single tank, it's more about the fact that if I can see the fuel brimming at the top of the filler, I absolutely know how much fuel I used since last time the fuel was brimming (as oposed to always filling to the first click, or other methods), so as to make accurate mileage calculations.
    Am I right or wrong here?
    ClintJ001 likes this.
  4. Frank Hudon
    Frank Hudon Senior Member
    4,147
    it is generally agreed that N. A. is the only ones with the bladder in the tank. JDM and Europe don't have the bladder and it's assumed that Auz and N. Z. don't as well.
    Edit: the part number on the NA tank is 77001-47080 call your dealer parts dept and ask for the pn on the Auz tank and compare.
    jocogi likes this.
  5. fgray30
    fgray30 New Member
    17
    <div class='quotetop'>QUOTE(Frank Hudon @ Jul 30 2006, 11:25 AM) [snapback]294628[/snapback]</div>
    Hey Frank, thanks for the info. I'll call the dealer in the morning!
  6. Tideland Prius
    16,155
    I don't think you Aussies have a bladder. I remember one owner who just got his Prius and did 900km on his first tank. No way in heck can our NA Prius do 900km on the first tank with the bladder.
    Also, note that the Japanese can fill almost 60 litres into this supposed 45 litre tank giving them nearly a 2000km range.
  7. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    I don't know if you Australians have the fuel bladder system, but from the difficulties you had in overfilling your tank, it sounds like you do, but others say no . . . ask your dealer.
    What I am sure about is that you have a charcoal canister for the Vapor Recovery System (EVAP). Over filling the tank can cause the charcoal canister to become contaminated with liquid gas and can cause habitual overfillers to receive a Check Engine warning light, decreased fuel economy, difficulty adding fuel, and gas vapors escaping into the atmosphere, etc.
    Ask your Australian Toyota dealer if overfilling is a good idea.
    This may be helpful . . .
    http://priuschat.com/index.php?s=&showtopi...indpost&p=90480
    Also do a PriuChat search for “Charcoal Canister†for more information.
    It's amazing to me that the US 2005 Owner's Manual doesn't mention the hazards of overfilling the gas tank. <_< (I can't speak for manuals from other countries or years)
    jocogi likes this.
  8. Mish
    Mish New Member
    Australia
    I read somewhere that if you have a bladder you shouldn't overfill it as it can stretch the bladder etc. Although I'm not sure if this true. I know there are no warnings associated in trying to fill aircraft with bladder tanks up too much. However the system (from memory) has a sensor that cuts the fuel filling off when it reaches a certain level.
  9. fgray30
    fgray30 New Member
    17
    <div class='quotetop'>QUOTE(Tideland Prius @ Jul 30 2006, 12:32 PM) [snapback]294658[/snapback]</div>
    Hey Tideland,
    It seems the concensus is no bladder. 60 litres in Japan? That's a lot! Is this just filling until the click or spending half and hour put in the last few CCs?
    Any other Aussie owners want to chime in with how much they usually get in the tank? Mine ranges from 42 to about 48 litres was the highest.
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy @ Jul 30 2006, 12:48 PM) [snapback]294665[/snapback]</div>
    Hi Sufferin',
    Thanks for that link, very interesting reading indeed.
    I do remember reading some posts where the owner could see the fuel level off and stay in the filler neck. My questions is this: it seems like I can keep adding fuel and it just keeps taking more and more. Does all of this fuel actually go into the tank, or does it get bled off as "waste" somewhere and rendered unusable? There is no fuel on the ground when I drive away.
    I have not had the patience to keep pumping past the 48 litre mark, but if I did maybe it would take the 60 litres that the Japan guys are getting?
    P.S. I keep the nozzle out of the neck to make sure I can see the fuel actually leave the nozzle and drain into the neck.
  10. sleeka
    sleeka Member
    249
    Brisbane. Australia.
    <div class='quotetop'>QUOTE(fgray30 @ Jul 31 2006, 06:06 PM) [snapback]294956[/snapback]</div>
    G'day, fgray30.
    Good to see another Brisbane owner here. What side of town do you live?
    Re: the Aussie fuel tank...we definetly have a solid metal tank (and a charcoal canister vapour return system). Having never emptied the tank, I couldn't tell you how much it actually holds, but as 45 litres is the official legally nominated capacity for OZ cars, I would be very surprised if Toyota's figure is wrong.
    A full fill (whatever that might be) does take a while...and plenty of patience to fill to the top of the neck, wait while it settles, fill to the top again etc etc. It will eventually hold a level at the top, and we have then gone around 950 km with 1 bar still up on the gauge. At that point, 41.5 litres went in. If you have put a genuine 48+ litres in, then it must be going somewhere, or the pump is grossly optimistic.
    Regards,
    Sleeka.
  11. Aussie56
    Aussie56 New Member
    34
    I fill up as much as possible each time because I get a service charge on the BP card for each transaction. It's not too big a deal, because I pay for petrol out of my pre-tax salary as part of the novated lease. I use so little petrol compared to budget that they set next years fuel budget to $1 so that they didn't forget to allow for fuel the following year :)
  12. fgray30
    fgray30 New Member
    17
    <div class='quotetop'>QUOTE(sleeka @ Jul 31 2006, 10:30 AM) [snapback]295101[/snapback]</div>
    Hey sleeka,
    I am on the north side mate and work in Toowong, what about you? My general rule of thumb is to fill up as soon as I can after the "add fuel" warning and the last pip starts blinking. Usually comes on around the 1,050km mark. As I said I've put in anywhere from 42 to 48 litres - could be an over-optimistic pump! (Woolworths at Chermside).
    So in your experience you have seen the fuel settle at the top of the filler neck - interesting. I will be more patient at my next fill-up!
    Also, the 48+ litres may be genuine as the Japan guys get nearly 60 litres in and I don't think there would be any reason for them to have a different tank than us?
  13. Tideland Prius
    16,155
    They have the same 45 litre tank. Supposedly, they tilt the car while refuelling. The lift the rear left wheel using a wheel block wedge.
  14. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    Hello from Japan.
    Tideland is right Japanese tank specification is also 45 liters same as Australia.
    We usually put max about 49 liters with slow filling in five minutes on a flat surface.
    However, if the surface is inclined as a picture below, then we'll able to put max about 60 liters with slow filling in ten minutes with shaking body well. ;)
    Ken@Japan
  15. Tideland Prius
    16,155
    Ken, where does the fuel go? Are you sure Toyota didn't just give us a 50 litre tank from the Corolla? lol. That or we have one hell of a long fuel filler pipe!
  16. sleeka
    sleeka Member
    249
    <div class='quotetop'>QUOTE(fgray30 @ Aug 1 2006, 01:05 PM) [snapback]295495[/snapback]</div>
    Hi fgray,
    I live and work at Riverhills....westside, not far from Toowong. We should meet sometime and compare cars.
    PM me your email if you'd like to, and we can arrange a time.
    We normally don't let the tank drop below 2 bars, my wife does a fair few k's for work in the Prius, so we prefer to keep it topped up (and also play the petrol companies' discount cycle to our advantage). Have you tried the E10 blend fuel? Our car seems to like it, and gives better economy on it.
    What model Lexus did you have, and how do you find the Prius after that experience?
    Regards,
    Sleeka.
  17. fgray30
    fgray30 New Member
    17
    <div class='quotetop'>QUOTE(ken1784 @ Jul 31 2006, 11:20 PM) [snapback]295543[/snapback]</div>
    Hi Ken,
    So tilting up at the left lets you put in 10 more litres? What about when the car drives off on level ground again - are there risks of overflow anywhere?
  18. fgray30
    fgray30 New Member
    17
    <div class='quotetop'>QUOTE(sleeka @ Aug 1 2006, 09:58 AM) [snapback]295670[/snapback]</div>
    Sleeka,
    PMed you about meeting up.
    Yes I have tried the E10 on one tank, consumption immediated went up to around 4.3 to 4.4 for the tank instead of my usual 3.9 to 4.0 - same driving conditions and my tank averages are usually very consistant.
    I have a Lexus ES300 (still have it actually). How do they compare? Very different in many ways of course. You almost can't beat the smoothness and quietness of a Lexus, and I notice this immediately every time I drive it. Both low and high-speed ride goes to the Lexus hands-down.
    More road noise in the Prius but less wind noise. Handling both on the spongy side. Much more rear leg-room in the Prius was a pleasant surprise! If I sit behind where I usually have my driver's seat in both cars, the Lexus is a little tight, the Prius I can really stretch out, especially as there is loads of room to put your feet under the seat in front. Also much easier to get in and out of (I am about 6'3).
    Fuel economy of course are worlds apart. I drive the Lexus gently and it returns about 12.0l/100km - can go much higher if flogging it.
  19. ken1784
    2,940
    1,365
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(fgray30 @ Aug 2 2006, 10:37 AM) [snapback]296017[/snapback]</div>
    Yes.
    I've never heard any problems about this. But, it's at your own risk. ;)
    Ken@Japan
  20. ClintJ001
    ClintJ001 Junior Member
    Australia
    No way 60lt in an Aussie tank. Squeezed a tad under 45lt from blinking light
