"Ours" vs "Theirs"
Discussion in 'Prime Main Forum (2017-2022)' started by Prime Example, May 29, 2017.
  1. Prime Example
    Prime Example Junior Member
    58
    99
    Shenandoah Valley
    52,409
    prius is still a bit tree hugger, volt more technical.
  3. Prime Example
    58
    99
    Shenandoah Valley
    The Volt seems like a really nice car. But, I'm not particularly fond of the infotainment screen and the dash. I prefer the Prime's - both the large one and the one in the Plus version. I was also surprised that although the electric range is greater than the Prime's, the MPG in the Volt was significantly lower. Also, I was surprised at the relatively long charge time for both L1 and L2 on the Volt. While the Volt would have been a very fine car, I am so very happy with my Prime.
    #3 Prime Example, May 29, 2017
    52,409
    of course, brochures and real life are different things.:)
  5. ArcPrime
    ArcPrime Active Member
    201
    166
    Arcadia, California
    Volt has a smaller engine and gas tank. I guess Chevy traded gas tank for battery size. However same 12 AMP battery charger, takes longer twice as long to charge battery. Even I like bigger battery but 13 hours 110 home charger just too long. Even @240V still takes 6 hours.
    One good thing Volt doesn't have white center counsel.
  6. El Dobro
    El Dobro A Member
    7,093
    3,271
    The Gen II Volt is charged at a little more than 4 hours with a Level 2 charger. With a Level 1 charger, it takes a little more than 8 hours at the 12 amp setting and a little more than 12 hours at the 8 amp setting. With a smaller battery, the Gen I takes less time, of course.
  7. stevepea
    stevepea Senior Member
    535
    581
    The Volt is a good car, and I looked at it and seriously considered it, but settled on the Prime. I really loved the double EV range, but my drives are almost all well over 100 miles (meaning gas will be burned at some point) and the difference between 42 and 55 is huge. Plus didn't like the high deadpedal on the Volt, and Chevy's rep for quality hasn't always been stellar (though that is changing). To each their own, two good cars, that I wish some Enormous SUV drivers would trade their guzzlers in for...
  8. bwilson4web
    16,382
    Page 2 of the Volt document had the word "green". A quiz: at what page does the Prime flyer reference 'green.'
    As long as traditional car makers think efficient cars must appeal to 'green' motivated owners, they will miss the rapid acceleration that EV motors provide. They will continue to build cars that do not exploit the advantages of EVs in making cars that scoot across the intersection faster than their 'simple' cars.
    #8 bwilson4web, May 30, 2017
    Felt likes this.
  9. bisco
    52,409
    i didn't see the word, it just came into my mind on the first page as they flew the r/c plane out over the mountainside.
  10. Mendel Leisk
    41,934
    No page number that I can see, first (and only) instance is as a trademarked descriptor "GreenEdge" for the sound system's speakers, which Toyota claims make more sound with less power.
  11. Trollbait
    12,691
    Car design, like life, is finding balance. The Volt hybrid mode could have been more efficient, but that would have increased the price of the car. The Malibu hybrid beat the current Camry one by 6mpg. Step outside the hybrid bubble, and you'll find that among what the vast majority of what cars Americans are buying, GM competes with and even beats Toyota in fuel economy.
    It also takes longer to fill up our Sable than the Sonic.:) Another way to view plug in charging is to look at the miles a range gained over an hour of charging. At AC Level 1, that is pretty much 4 to 5 miles per hour for all plug ins. Get home for work with the battery depleted, plug it in, and an hour later both the Prime and Volt have enough EV range to pick up a pizza from the local place.
    The Volt is the high performer among Chevies in reliability.
  12. El Dobro
    El Dobro A Member
    7,093
    3,271
    The Volt isn't really too bad with gas on the highway, better than a lot of other cars. This past weekend, on my way back to NJ, I filled up in Ashland, VA and reset trip B to 0. With 30 miles on the battery, I drove with it on hold until the GPS said I had 33 miles to go to home, and then switched over to EV. When I pulled into my driveway, I was still on EV and had 2 miles left on the GOM. This was with my Gen I and if I had a Gen II, I know I would have easily beat the figures. Just sayin'. ashland.jpg
    Trollbait likes this.
  13. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    According to fueleconomy.gov, the volt costs $8/month more in fuel to drive 15,000 miles/yr (80% hwy calculation). Is that significant?
    Compare Side-by-Side
    Once past 40mpg, gas savings drop considerably. That's why going pure electric drive is the next step in efficiency.
  14. bwilson4web
    16,382
    Nice, here is what I did on the drive home in our Prius Prime Plus:
    I was using dynamic cruise control to follow high-balling trucks. There was one fill up half way home.
    So @El Dobro, should we also troll the Volt forums following your example?
    #14 bwilson4web, May 31, 2017
  15. bisco
    52,409
    only if your commute varies widely from what they use. can be deceiving to some who might not understand.
    volt would cost me a fortune due to my electric prices.:mad:
    bwilson4web likes this.
  16. fotomoto
    5,639
    3,815
    So. Texas
    You can change the calculator to better reflect one's own usage which is what I did to better match stevepea's drive (mostly hwy). If one drives lower miles and mainly city like you and me, gas economy is basically meaningless since I only buy 2-3 tanks per year.
  17. bwilson4web
    16,382
    FYI, @bisco lives in an area where the electric rates make gasoline often more affordable or equal cost option to electric miles.
  18. bisco
    52,409
    i'm thinking of buying a big suv to save money.:cool:
  19. El Dobro
    El Dobro A Member
    7,093
    3,271
  20. Trollbait
    12,691
    What speed were you traveling at?
    That's better highway than what I've seen in a gen2 Prius, but the trip had speeds over 70mph and even 80mph.
    Using MPG is a disservice to consumers. A gallon per mile, or set of miles, would make the financial effects of different fuel economy more visible
    With about 3000 miles driven a year, comfort trumps fuel economy in regards to the wife's car.
    Not off the table here:cautious:
