Outside air temp gauge
Discussion in 'Prius v Main Forum' started by Lildevil, Jul 28, 2023.
  1. Lildevil
    Lildevil Junior Member
    30
    Omaha, NE
    What is the maximum that the outside air temperature indicator will read? Mine shows 85 when it is 98 outside.
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,975
    4,716
    Texas Hill Country
    Pretty sure I have seen 104f in the past. At the moment it is reading 96f in a garage which is accurate.
    Air_Boss likes this.
  3. fuzzy1
    10,170
    I saw 106F a week ago, on the other side of this state. Regular 2012 Liftback, not v.
    Lildevil likes this.
  4. Lildevil
    30
    Omaha, NE
    Thank you, that confirms to me that my sensor is bad.
  5. bisco
    49,490
    how long are you out there? mine takes about an hour to reach full temp after leaving the garage
  6. Lildevil
    30
    Omaha, NE
    I am out there over an hour. Thank you.
  7. rjparker
    7,975
    4,716
    Texas Hill Country
    The only time my outside temp is wrong is after a car wash. It will read 10-15 degrees low before it dries off. Maybe ten minutes.
    djasonw likes this.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Not really surprising that it might be bad after 10 years.
    But it is trying to read the temp where it is actually located which is always in the shade.
    And if the car is not moving and not running, the metal body might be slow to heat up.
    It bears some observation in various conditions before you decide that it really is "bad".
  9. rjparker
    7,975
    4,716
    Texas Hill Country
    Thermistors rarely go bad from a calibration standpoint. They sometimes open and more rarely short which are detectable conditions. About the only way to be 13 degrees low is through a high resistance connection given a ntc thermistor.
  10. sam spade 2
    7,035
    2,788
    2017 Prius c
    What about the rest of the electronics that translates the current flow into a numerical reading ?
    The "fix" for this might not be as easy as the OP imagines.
  11. rjparker
    7,975
    4,716
    Texas Hill Country
    A to D converters are not in the eighties these days.
  12. sam spade 2
    7,035
    2,788
    2017 Prius c
    Meaning what exactly ?
    Regardless of design, it can fail.
  13. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    FWIW, OAT probe on the 1996 Dodge Grand Caravan failed after 10 years... Easy plug and play fix.
    #13 Air_Boss, Aug 1, 2023
  14. Mendel Leisk
    38,726
    Replacement might be simplest, if it’s cheap. If it’s costly and you want to diagnose: I don't have Prius v, but here's some Repair Manual info hopefully similar:
    Temperature range:
    Trouble code:
    Attached is the trouble-shooting procedure for above DTC code. Again, hopefully is similar for the Prius v.
    #14 Mendel Leisk, Aug 1, 2023
  15. ChapmanF
    15,615
    I'm with rj in thinking a connection adding to the NTC thermistor's apparent resistance (and thereby reducing the reading) probably more likely than badness of the thermistor itself.
    Replacing the thermistor might well fix it ... because you would have unplugged and replugged the connector where the extra resistance probably is. ;)
    Air_Boss and fuzzy1 like this.
  16. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    [QUOTE="rjparker, post: 3373079, member: 41651"... About the only way to be 13 degrees low is through a high resistance connection given a ntc thermistor.[/QUOTE]That condition would adversely affect readings at all temperatures. Lildevil wasn't clear whether that's the case (vs. malfunctioning only at T>85°)
  17. ChapmanF
    15,615
    All the same, I haven't heard of a thermistor itself going bad in some "only at T>85°" way either.
    Because the resistance of the NTC thermistor goes down as temperature goes up, if there is some extra fixed resistance in the circuit somewhere, it will be a bigger proportion of the total resistance when the temperature is higher. It will always make the reading too low, but by worse amounts at higher temperatures.
