outside temp gauge not working
Discussion in 'Gen 2 Prius Technical Discussion' started by josemedina, Mar 1, 2010.
  1. josemedina
    josemedina Junior Member
    25
    San Antonio, TX
    I just got my 2006 Prius out of the body shop after hitting a whitetail buck. $7100 later it is fixed and good as new except now the outside temp gauge does not read anything. I guess they forgot to plug it back in or something. Does anyone know where the sensor is located? I have a call into the body shop but I have not heard back yet.
  2. Patrick Wong
    18,200
    6,493
    The sensor is located in front of the radiator, and can be seen if you look in the space between the front bumper and the radiator. If you don't see a sensor and instead just see a wiring harness connector connected to nothing, then you'll know what the problem is...
  3. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    Interesting! So you mean the Toyota has a separate sensor for the temp gage? Many cars use the intake air temp and just digitize the resistance to a temp figure. After all, the computer needs outside air temp for its functions - why not display a value?
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Yep, they use a separate sensor located at the front of the car. Presumably they did this to get a temperature reading undisturbed by engine heat.
    Here is another bit of trivia, at least for the Gen II Prius: the outside temperature sensor reads in °C. For the U.S. models, the °C reading is converted to °F. If you watch carefully, you will notice that the outside temperature reading jumps 2° at a time most of the time. This is because there are 1.8 °F for each °C.
    Tom
  5. Patrick Wong
    18,200
    6,493
    Yes, the Prius also has an intake temp sensor within the MAF sensor.
    Have you noticed that when you wash your car, the outside air temp shows a lower than normal temp for a while? This is because the sensor near the radiator got wet. Until it dries off, the coating of water will cool the sensor below ambient air temp.
  6. josemedina
    25
    San Antonio, TX
    Wow! The body shop discarded the sensor with the other parts and now they have to order it. Thanks for the help.
  7. qbee42
    18,058
    3,076
    Northern Michigan
    So now you know the temperature in some landfill. :D
    Tom
  8. klb1963
    klb1963 New Member
    Palestin, TX
    I am having the same problem with my car. I had the front bumper replaced and now the outside temp gauge says 40 degrees when it is 108 outside. It is affecting the airconditioner. I looked and seen the gauge just dangling in front of my radiater but I have no idea where it is supposed to be clipped to. Anyone have suggestions?
  9. vertex
    vertex Active Member
    672
    143
    new york
    2018 Prius Prime
    I think it goes into a hole on the hood release bracket.
  10. koolingit
    koolingit Member
    158
    51
    Mocksville NC, USA
    It clips to the bottom of the vertical support that runs down the middle of the condenser. It has red and white wires connected to it.
