Outside Temperature and MPG relationship
Discussion in 'Gen 2 Prius Fuel Economy' started by duffetta, Jun 17, 2005.
  1. duffetta
    duffetta New Member
    Boston, MA
    I live near Boston and have had our '04 since Oct. 04. I drive about 30 highway miles round trip over a somewhat hilly terrain daily.
    During the winter I experienced mid to upper 30s for MPG. We had a particularly nasty winter. When things warmed up we took a trip to NYC and averaged (roundtrip) 52 MPG. The ave temperature during the trip was in the 60s and 70s.
    Last week, the temperature was consistently in the 90s, and I couldn't get the MPG above about 42! Now that it has cooled off to the 50s again (A 40 degree change over night!!!), I am in the upper 40s!
    So, my observation is that at least my '04 prius likes the temperature to be between the mid 50s and the mid to upper 70s. Is this what others are observing as well?
    Thanks,
    Mark
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Not at all, and I suspect some other factor(s) are involved in your case. Up until you hit 95 degrees or so, with modes AC use, you should see better and better mileage. I'm seeing 59.7 right now with temps averaging low to mid-80s.
    I honestly mean no offense, but with a 30 mile commute, unless it's all either stop and go, or all speeds above 65mph your lower mileage is probably due to your driving style.
  3. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
    I'm in agreement with Evan 100%. On my tanks that are near 60 MPG the temps in the morning are mid 70s and in the afternoon are mid to upper 90s.
    Sitting in traffic without moving with the AC running will kill the mileage. I often roll down the windows if I'm sitting at long lights. Once I'm moving I turn on the AC and roll up the windows. There are limits to this strategy based on comfort. Personally, I'm uncomfortable with watching my mileage vanish while sitting at a light.
  4. duffetta
    duffetta New Member
    Boston, MA
    I don't disagree that my driving style is having an ill-effect on my MPG. The hills aren't exactly helping either. At the same time, my driving style doesn't change with the temperature.
    There is very little stop and go traffic during my commute. I don't like to run the AC, but I do when the temps are above 90. Also, I don't open the windows on the highway, mostly due to noise. So this should be the best situation for MPG: no AC and windows closed to maintain good aerodynamics. Open windows will create some drag.
    As for speed, I am normally crusing around 65 mph on the highway, and in the 30s and 40s on a smaller divided secondary road with some traffic lights. To some degree the highway speed is influenced by the impatient commuters in and around Boston.
    So, time for me to improve my driving style. Once I improve this, I'll look at the temperature issue again.
    Thanks,
    Mark
  5. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    I have lots of hills and the temp varies wildly here in the desert. Temps go from 30 deg in the morning to 105 in the afternoon (this psat week). So each day I get each extreme (although the last week it has only gotten to mid 60s in the morning). My fuel economy has pretty much stayed steady. Only about a 1-2 mpg hit for A/C or heater use. I travel the spd limit about 10 mi at 35 mph, 15 mi at 60 mph, then 5 mi at 25 mph. Lots of hills and windows open the first and last leg of the trip just in the mornings. I do tend to coast a lot and use cruise control unless I go below 24 mph. If no one is behind me I drive the spd of the terrain (between 2-10 mph slower than posted and up to 5-10 mph faster due to hills or stops less than 100 yds apart).
  6. vprius
    vprius New Member
    42
    Bakersfield, CA
    Actually I seem to notice this temp/mpg difference also. I think extremely warm temps (above 90) seem to bring down the mileage. We had a cool snap (only 79 yesterday) and my mileage improved about 5mpg. Don't think I was driving any different than I normally do, and I was in the same area as I usually travel.
    I've only had the car a couple months, but I've noticed the mileage seems to suffer as it is getting into the 90's. My worst mileage to date was on a day in the low 100's. Of course I was running the air...no way around that. I'm not going to cook to get better mpg. 8)
    I think it is necessary to keep the car cool to keep the battery cool? I may be mistaken on that point, but somehow got that impression. Is there any way to tell if the car/battery is overheating? I guess I should read the manual more carefully, but I don't see any gauge. I do remember that I'm not suppose to cover that vent in the back, so I figure it draws in cool air from there.
  7. efusco
    19,891
    1,192
    Nixa, MO
    Yes, keep the car cool enough to cool the battery. those of us with an EV button can't engage EV mode when the car/battery temp is high (above 95-100??). And once the battery starts working it generates it's own heat and thus needs even cooler air to bring down the temp.
    I usually run my AC at about 78-80 degrees. that's plenty comfortable if the car doesn't have 5 passengers and doesn't seem to adversely affect mileage...in fact I think it actually helps some b/c of the ill effect of the heat on the battery.
  8. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    I'm in the Boston area too, and yet I find warm weather really helps mileage. Hot weather here so far seems to help more than the drain of using AC.
    My commute is mostly at 30-40 mph on back routes, or 55 to 60 max on toute 128.
    At say 50 degrees I might expect a commute at 60 plus mpg the back route, or 52 on 128.
    At 80 degrees I might get over 70 mpg the back routes and over 55 on the highway.
    Driving highway like if I go up 93 or on 495, I lose maybe 3-4 mpg due to the higher speeds.
    But still warmer is better.
    Someone had curves here I think, or maybe it was yahoo. Anyway from looking at them (they were just drag vs temperature and speed data) I noted that driving 55 mph in cold winter weather was about the same mpg wise as driving like 70 mph in hot weather.
    My current commute is only12 miles each way. I have many trips less than that to shop.
    My mileage dropped to low 40's in winter. For the last 4 tanks I have averaged over 51 mpg.
  9. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I can testify that sitting in traffic in 90 degree weather really kills the gas milage. I had a tank average of 55 last month and the temp went to the 90's. I thought I would clean up and get my first 60 mpg tank but for what ever reason the traffic got really awful, like waiting for the light to change 3 times before you even get to the intersection. No accidents just everyone going the same direction at once and my milage went down and down. Also around here even if the highs are in the 90's the lows will be in the low 50's so the morning commute can be a bit lower. Next time I am not going to drive the shortest rout but go around and be able to move!
  10. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    well temps in the morning have reached 86 deg and afternoon are now 105+ so I am using the auto A/C more now which has droppd the MFD about 4 MPG. :(
  11. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    <div class='quotetop'>QUOTE(duffetta\";p=\"99289)</div>
    What temperature do you set the AC for? If you are setting it to something like 72 or below on a sunny 95 degree day, then that's what's dropping your milage.
    When the AC is running full out, it really sucks down the battery charge. That causes the engine to run more and for it to put more of it's output into charging the battery.
    I have found that on really hot days like that, setting the AC to 78 is sufficent. The AC doesn't run full out like that and after driving for a few minutes, the Auto/AC sets the fan speed to medium low. With the cool air from the vents aimed right at me, it feels just fine.
    For cooler days (mid 80s), I will often set the temperature between 74 and 76.
    With these settings, it doesn't seem to put too much of a dent in my mpg.
  12. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    That's my experience, especially coming home where the cabin is really hot. Last week, the temps even at night wouldn't go much lower than 80, and so even my moring, late evening trips had more of an MPG hit than mornings this week. I currently have my temp set to 75.
  13. ihatemyusername
    ihatemyusername New Member
    Here in phoenix the temps have reached 110 to 115 and with the added AC usage, this has dropped my mileage below 40 for the first time :( . That's ok though: it still beats the truck's whopping 13 mpg!
  14. bigdaddy
    bigdaddy Member
    991
    Duluth Georgia
    I saw a cool spreadsheet in the Yahoo Prius-2G forum, which laid out expected fuel milage based on temp and speed. It is in the files --> 2004 prius simulations section. US is second tab in the spreadsheet. Pretty enough to print out. Not sure of the background of the calculations....
    2004 Prius - Palm THS2 Simulation (SI, US & UK).xls
    3D simulation (xyz, x=speed, y= temperature and z= fuel consumption results, 15x21 = 315 points, 15 temperatures and 21 speeds). By Didier LUSUARDI
  15. priusham
    priusham New Member
    525
    Michigan - land of everlasting snowflake icon!
    You guys are killing me...
    You want to talk mileage killer? Try driving in Michigan all fall/winter/spring and having to run the HEATER and DEFROSTERS!
    These two (which I might add - unlike the electric AC) actually requires the ICE be running AND the AC compressor to run! Plus, the engine has to stay hot to keep the coolant warm!
    It's a double whammy.
    Proof here: www.w8kc.com/priusmileage.htm
  16. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    temps make a huge difference. i figure i average close to ½ mpg more in the evening coming home (avg temp around 70-80º) then the mornings (avg temp 50-60º)
    normal startup in morning... lose .2-.4 mpg on tank at beginning of drive. it slowly rises back after about 5-7 mins of driving.
    in evening, lose .1-.2 mpg at first, then it rises back up, most times, im .1 to .2 mpg higher when i get home. my commute is about 8.7 miles. small changes in elevation, but overall change is only 35 feet.
    i have only used air conditioning a few times this year and none were afterwork commutes. (i dont get off work until after 7-8 PM most days so i miss the hot part of the day)
    and i have to agree with many here. i believe my mileage would continue to improve as long as i didnt use the air conditioning. now getting great mileage makes me feel great, but i dont think it will overcome driving in 90+º heat without air...
    so for you, definitely look at congestion first before temps. your long trips getting 50+ mpg on the freeway is normal. getting any worse than that under any legal circumstances has to do with congestion, poor anticipation, or a desire to spend a lot of parking time at each red light.
  17. duffetta
    duffetta New Member
    Boston, MA
    Thanks, I'll give this a try. We hit something like 98 today but did all of my trips in the Prius this morning before AC was necessary. The afternoon trips were all in the Honda minivan.
