Outside Temperature display
Discussion in 'Gen 2 Prius Main Forum' started by Middle_Age_Moment, Feb 20, 2004.
  1. I've asked this before but can't locate the info. So, again I ask: Can the outside temperature display be tweeked up or down by a tech?
    My outside temp display is consistently 4 degrees higher than actual.
  2. glscheil1
    glscheil1 New Member
    150
    Raytown, MO.
    Don't think so. All they can do is install a new sensor.
  3. DaveG
    DaveG Member
    806
    Vancouver, BC
    Yes, there's an option to adjust by +/- 2 degrees celcius.
    You need a Toyota dealership with a scantool to do the change.
  4. Fredo
    Fredo Junior Member
    45
    If the adjustment is +/- 2 C, that would about adjust for a 4 degreee Farenheit variance. Hopefully, the dealer hadn't already adjusted it.
