Outside Temperature is way off.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Dale Wurm, May 12, 2016.
  1. Dale Wurm
    Dale Wurm Junior Member
    I have a 2012 PiP and I live in Florida... The outside temp shows negative 18 degrees when it is around 90 degrees. This has happened before and it took about a month or two for the problem to go away. Now the problem is back again. I could live with the fact that the temp shows incorrect, but because the temperature shows that cold the auto climate control turns on the heat when it is around 90 degrees outside. Thanks for any suggestions anyone may have.
  2. mrbigh
    3,686
    699
    Long Island, NY
    make believe you have Alaska temperatures while you are wearing shorts every day......:cautious:
  3. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    Anyone know where the temperature sensor is on these cars?
  4. drash
    drash Senior Member
    2,553
    1,297
    Upstate NY
    I thought the ambient air temp sensor was in the fuel tank like it is the Gen 2 Prius.
  5. bisco
    51,154
    i thought it was in front, near the bottom of the radiator. as to the o/p's problem, there have been complaints of slow temp change time, but not this iirc. not sure if it's the sensor or the computer though.
  6. drash
    drash Senior Member
    2,553
    1,297
    Upstate NY
    I found it in Toyota Hybrid System Diagnosis - Course 072. Section 3 Fuel and EVAP system.
  7. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    Sitka Alaska last Wednesday. 70 degrees, sunny, light breeze.
  8. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    Sounds to me like the thermocouple is broken maybe getting moisture causing a short until the moisture gets out
