Outside temperature Prius 2017
Discussion in 'Gen 4 Prius Main Forum' started by Huseen0788, Sep 27, 2019.
  1. Huseen0788
    Huseen0788 New Member
    Jordan
    Dears
    Do you know where is the location for outside temperature sensor for Prius 2017
    I need real pictures for sensor please I search for the internet I have only diagrams for it please I need real picture for the sensor because the temperature it’s wrong every time temperature in -12f -15 -10 like this
  2. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
  3. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,585
    near Brisbane, Australia
    It'll never be accurate - it takes the temperature of where it's located. Not sure about where it is on PRIUS - my last car was behind the front bumper cover quite low toward one side..
    • If it's been parked under a tree, it's quite accurate - sort-of.
    • If it's been driven and just parked on a hot surface - tends to read high, I suspect, because of radiant heat from the road.
    • Parked in the sun - gives a reasonable idea - but I wouldn't say accurate.
    • Parked in an underground carpark - reasonably accurate - but bear in mind radiant heat from engine/radiator will make it read high if it's only just been parked.
    I think it's more for entertainment purposes "guess what the real temperature is".
    Maybe tow one of these Stephenson's Screens - which comes with quite prescriptive instructions on installation.
  4. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    On our 2016 Prius v Three the sensor is located under the front bumper...
    alanclarkeau likes this.
  5. alanclarkeau
    7,044
    7,585
    Found it:
    It's listed in among the components of the AirConditioner Neural Network Control.
    The A/C uses it, as well as other sensors etc to run the A/C:
    kithmo likes this.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    THIS is all you need to know.
    Not worth your time, money or trouble to try and make it more accurate.
    That would be a losing proposition.
  7. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Same place as the Gen 3 then (OP has 2012 in his sig).
