Outside Temperature sensor question
Discussion in 'Gen 3 Prius Main Forum' started by marcmdm2005, Jun 22, 2021.
  1. marcmdm2005
    marcmdm2005 New Member
    Omaha, Nebraska
    I bought a 2010 Prius and it was wrecked previously. Question is do I need this sensor?
    Thank You
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,557
    6,623
    Texas Hill Country
    It is used by your ac.
  3. marcmdm2005
    Omaha, Nebraska
    So pretty important?
  4. rjparker
    10,557
    6,623
    Texas Hill Country
    The ac uses outside temp and a solar radiation sensor to bias the output temperature using a high voltage three phase variable speed compressor. It is quite a system, technically far more advanced than your typical residential system.
    paolo.rapana and marcmdm2005 like this.
  5. marcmdm2005
    Omaha, Nebraska
    Thank You I picked one up with harness and got it installed!
  6. Mendel Leisk
    41,928
    Maybe the outside air temp is also used by the car's computers to tailor engine warm-up? Or is it just monitoring coolant temp? I know in winter the engine runs longer before starting to shut-down, say at red lights. And you can tip it to shut-down sooner, if you keep the H/V system temp low, or shut the system right off.
  7. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    its also used in tandem with the hvac; engages from recirc to outside air to come in so windshield doesn’t fog up. During winters and skunk season, I don’t like this feature.
