Overfilled gas tank, did I hurt it?
Discussion in 'Gen 2 Prius Main Forum' started by MCCOHENS, Feb 9, 2023.
  1. MCCOHENS
    MCCOHENS Member
    189
    81
    Chalfont, PA
    Should have realized something was wrong, my go to station was pumping very slowly. Took as long as the silverado to fill. Then the counter went past the normal teens dollars. I figured maybe the gauge was off or my mileage dropped from weather so I let it run. At low 20s $, probably around 7.5 gallons gas started pouring out of the filler tube! The shutoff was not functioning. It puked at least a quart out while I called for the attendant.
    Ran next door to the hardware store to get a can and siphon to draw down the level.
    Store manager was very nice, he explained that the filters were due for a change and because of that the flow slowed and shutoff didn't work. Got reimbursed for the hardware and a free tank of gas along with a free car wash.
    My concern is does overfilling hurt the rubber bladder in the tank. I pumped as much as I could with the siphon but it only goes down the neck so far. And yes I will avoid this station for a month and NEVER try to fill if it is running slow.
    49,526
    Not necessarily
  3. Todd Bonzalez
    Todd Bonzalez Active Member
    250
    160
    Ireland
    The excess gas came back out the filler neck. Sounds like the expected operation, as the bladder surely can't over-expand due to the physical constraint of the tank itself?
    49,526
    it's not the bladder. the excess gas enters into the emmision charcoal cannister and destroys it.
    there's no way of knowing except to wait for a trouble light. it's a complicated and expensive repair unfortunately
  5. ChapmanF
    15,708
    As bisco said, the risk is more to other components than to the bladder.
    There may be a trouble light later, or not. You may later have problems with fuel nozzles shutting off way early, and being unable to pump any more than a fraction of a tank. That becomes more likely for people with a long habit of 'topping off', but it isn't inevitable after one single time.
    So keep an eye on it for a while. If you notice any of those issues, you'll know what has happened, and if you don't ... go and sin no more.
  6. pasadena_commut
    pasadena_commut Senior Member
    1,502
    454
    Southern California
    Maybe just drive it for a while on the highway to burn off whatever liquid is in the canister? Not sure how long that would take if it is actually full of liquid, normally there is just the gas which is sticking to the charcoal, which would only be a tiny amount if it was all liquid. The purge valve would have to be open, but the Prius probably does that like any other car (as long as the motor is running).
  7. ChapmanF
    15,708
    Sometimes the system gets flooded beyond recovery, and repair is needed.
    As long as that didn't happen, it pretty much takes care of itself without needing much attention from you.
  8. PriusCamper
    PriusCamper Senior Member
    11,106
    4,521
    Pacific Northwest, USA
    The filters the hardware store guy mentioned is what normal metal gas tanks have to clean all the air inside the tank that is displaced when you fill up an empty tank. The bladder design eliminates the need for the filters because the collapsing of the bladder in the tank when it is empty means there's very litte air displaced inside the tank that needs to be filtered.
    It was a great idea in theory when it came to designing a car that reduced air pollution in every possible way. But in practice, the design in cold weather meant the rubber bladder doesn't expand fast enough and you get gas puked out. Toyota discontinued this design for that reason, as well as for inaccurate gas gauge readings.
  9. qmanqman
    qmanqman Active Member
    309
    112
    CO
    Just drive it til you go down a blip.
  10. MCCOHENS
    MCCOHENS Member
    189
    81
    Chalfont, PA
    The filter needing replacement is in the gas station system, not the car. Anyway, took it out for a drive, made it 40 miles before I caught a huge chunk of metal in a tire and it went flat in a second. The hole is too big to patch so I put on an old set of tires from a crashed prius that get scrapped. Now I have 195s in the back and 185s in the front. Will the computer be able to tell? Hopefully diameter difference is small enough to be OK.
  11. ChapmanF
    15,708
    If the ABS or VSC lights come on, probably the circumference difference is too big. Might only happen at higher speeds.
    If not, then the difference is small enough the ECU doesn't mind.
    The idea of the bladder tank was to perform even better than a tank with only the normal EVAP and ORVR stuff, not to have a bladder instead of the EVAP and ORVR stuff. The bladder tank still has that stuff. That's the stuff that usually gets hosed when the tank gets overfilled.
    PriusCamper likes this.
  12. Tombukt2
    Tombukt2 Senior Member
    9,226
    1,618
    Durham NC
    The traction control in the VSC light and all that should be on directly or be flashing on and off trying to get to speed from the non-matching tires I just went through this 3 weeks ago
  13. ChapmanF
    15,708
    If two tires have slightly different circumference, the wheel speed readings will be different, and the difference will be larger (in MPH) the faster the car goes. Twice the difference at 60 MPH as at 30.
    That's why, with a slight mismatch, sometimes you don't see any warning lights at low speeds, but only at higher speeds.
  14. mr_guy_mann
    mr_guy_mann Senior Member
    3,483
    1,587
    NJ-USA
    If the car "drives ok", then the tire diameters are close enough. The most likely problem would be if the sizes are too different, then the traction control would see a difference in wheel speeds from front to rear (usually at highway speeds). The ecu would flash the "slip" dash light while blipping the brakes and throttle to try and fix the perceived wheel spin.
  15. MCCOHENS
    MCCOHENS Member
    189
    81
    Chalfont, PA
    Well no problem so far, went 95 miles before the gas gage went down one bar, a new record. I have only had it up to highway speed for a few miles, and no issues. Need to take a road trip I guess. If it does cause a problem I am out $100 for a new tire. If not I have an extra in case this happens again. Both my daughter and I have the same tires so it is not bad having a matching spare for us.
