Overheating and confused
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Moekking, Jul 17, 2022.
  1. Moekking
    Moekking Junior Member
    911 I NEED HELP!! I have a 2010 gen 3 prius. I bought it used with arnd 189k on it. The only problem i had was it shutting off going dwn the road and the dash wld say chk hybrid system. It was engine coolant pump b. I replaced and havent had any other issues until now. It now has 234k on it and out of the blue one night my MIL light came on. Hooked up code reader and got p0117 ect sensor reading low voltage. Got a new aftermarket one (big mistake) and needless to say cld not clear MIL light and got code p0118. Ect reading high voltage. Got a factory sensor cleared MIL light and it hasnt came back on yet. Its been abt a week. My prob is now that its overheating. I bled the air out of the system after replacing the ect sensor and its full of coolant. I replaced the cap on my reservoir bcuz it wasnt building pressure. As a result it caused hair line cracks in my reservoir. I had to buy a new one that cost me $220!! I was shocked at the price. Anyways put the new one on topped of the coolant after bleeding air out again and took off dwn the road. Didnt make it far and the overheating light came on again. I got out popped the hood and there was no hissing or bubbling or anything but coolant was coming out of the little bleeder valve on top of the new reservoir and it had cracked my new tank jst like my old one. I dnt understand whats going on. Theres no chk engine light so im getting no code to diagnose the problem. And i dnt have the money to keep buying coolant tanks jst to crack them. As soon as i pull over the overheating light goes off amd still no hissing steam or bubbling. I let it cool dwn made sure it was full and limped home pulling over n letting it cool dwn again bfor driving any further again. A couple of weeks prior i had noticed my heat wasnt getting as hot as usual but didnt really think too much of it because its summer time. Now when the heat came out my vents you cld smell like it was melting my vents like burning plastic n if you your hand in front of the vents it was so hot it cld actually hurt you. Can someone PLEASE HELP ME??? im off for the next 2 days and thats all the time i have to fix it. Itsmy only means of transportation for me and my son. Im very mechanically inclined and wld prefer to fix this myself. That and i dont have the money to pay a dealership or buy a new car. Any help will be greatly appreciated.
  2. Tombukt2
    Tombukt2 Senior Member
    13,386
    2,409
    Durham NC
    If you're making that much pressure in your cooling system you need to be looking down line like in the thermostat area behind the water pump depending upon how you look at it a big black plastic fitting sounds like something is stopped up and is not pumping or recirculating when this heat is happening are both the hoses coming out of the radiator near the same temperature or is the bottom one really cold and the top one really hot or vice versa somewhere you've got a huge stoppage or extreme hindrance of coolant moving
  3. Mendel Leisk
    41,889
    Has the Exhaust Gas Recirculation (EGR) system, including intake manifold, ever been cleaned? (see first link in my signautre)
    If not you're in the thick of head gasket failure territory, with those miles. IIRC that does cause high pressure in the engine coolant circuit?
  4. BiomedO1
    BiomedO1 Senior Member
    4,116
    2,158
    SacTown, Ca
    check thermostat, fan, and water pump operations. There's a lot of counterfeit parts floating around out there. Make sure your coolant is moving and the fans are kicking on. I know Honda has a separate sensor/circuit that activates the cooling fans; so replacing the ECT wouldn't necessary fix the cooling fans from turning on; since they're on a separate circuit and sensor. This can also be something as simple as a fan relay failure - no CEL for that.
    Hope this helps
  5. Moekking
    Ive never cleaned the egr or intake since ive had the car however I replaced engine coolant pump B a while back. How wld i chk the pump? And also i was told that the thermostat was made into the housing so i does one chk that as well? Im a decent self taught mechanic but this hybrid stuff is new to me. Also how wld i chk for a clog somewhere in the system? Thanks for all the help guys. You have no idea how much i appreciate it.
  6. Mendel Leisk
    41,889
    Yeah again, see first link in my signature*, for EGR/Intake cleaning tips/links, especially "the easiest way to see where you're at...", for an easy first check.
    Still, with your miles, I'd suspect head gasket already failing. Is coolant level stable?
    * If you’re on a phone turn it landscape to see signatures.
    #6 Mendel Leisk, Jul 18, 2022
  7. Stu Wood
    Stu Wood Junior Member
    Bellevue, NE
  8. Moekking
    Cleaned out the intake egr and cooler. They were completely clogged. Put it all back together and its still over heating after abt 20mins running in maintainence mode. I thought maybe the heater core was clogged so i bypassed it n it still did it. And yes my coolant level is staying the same. Im not losing any.
  9. Moekking
    And my cooling fans are cycling on and off like they are suppose to. Still have no clue how to check thermostat bcuz its made into the housing. Or at least i was told that
    And i need all the help i can get guys. Im doin all the work myself. I work at lockheed martin in greenville sc and this car is my only way back and forth.
    #9 Moekking, Aug 5, 2022
  10. Tombukt2
    13,386
    2,409
    Durham NC
    You say your fans are cycling on and off like they're supposed to meaning what you should barely even notice this they should not be cycling on and off very rapidly even in South Carolina I'm here in North Carolina just a hundred miles away or so and in my 2010 and my 2013 cars got to be running a good minute to be having any fan action going on My Gen 2 or 3's never overheat that would be I don't even know what but then that would be a problem I've almost never dealt with in this particular models of car
  11. Minh
    Minh Junior Member
    22
    Sacramento
    Did you get a fix on your issue?
