Overheating only at high highway speeds
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Hitchhikin Taz, Dec 29, 2020.
  1. Hitchhikin Taz
    Hitchhikin Taz Junior Member
    North Carolina
    2014 Prius v wagon
    I get the red overheating signal at high end speeds of 80+mph. It turns off after I slow down to about 60 and won't turn on again unless I get back to 80+. The coolant has depleted slowly and I've topped it off every couple weeks. It's worse when the weather is colder.
    I used a coolant pressure test and it maintained pressure at 16psi. When I pushed it up to 20psi, it would slowly loose pressure. I wasn't able to see any obvious leaks. Under both circumstances, it would oscillate roughly .5psi up and down (not sure if that's normal).
    Thoughts on the dilemma? Head gasket issue seems to be the biggest fear.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Head gasket for sure
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,503
    6,593
    Texas Hill Country
    Start up rattle ever?
  4. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    In this case, no visible leaks suggests that you're blowing antifreeze through the exhaust system.
  5. ASRDogman
    ASRDogman Senior Member
    7,818
    3,982
    If you drive the speed limit, it's less likely to overheat. :)
    It also sounds like the head gasket is going. Pull the spark plugs and do the pressure test.
    Listen to each cylinder, and look for coolant on the pistons.
    You may also have a water pump going bad....
  6. Hitchhikin Taz
    North Carolina
    2014 Prius v wagon
    No
  7. Mendel Leisk
    41,898
    How many miles?
    ASRDogman likes this.
  8. ASRDogman
    7,818
    3,982
    I forgot to ask that. :)
    I had meant too, but was interrupted....
  9. Hitchhikin Taz
    North Carolina
    2014 Prius v wagon
    220k miles. No rattle on startup. Is it normal for the psi to oscillate at higher levels?
  10. rjparker
    10,503
    6,593
    Texas Hill Country
    I think there should be a new forum just for Gen3 Head Gaskets. A couple of stickies for Symptoms, Diagnosis, Repair Options, How Long Did Sealant Work and of course, Root Cause Theory of the Month. Extra points if your engine now has a hole in the side. Meetups to include White Smoke and Severe Rattle contests. Winner gets a JDM engine.
    #10 rjparker, Dec 30, 2020
  11. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Great suggestion. We also have to figure out better ways to keep non gen 3 users from posting non gen 3 stuff on this sub forum.
  12. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    by what?
  13. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    A poster once posted if your driving the speed limit, youre blocking traffic. Actual speeds are 5-10 mph faster than posted speed Block traffic or overheat your engine :ROFLMAO:
    #13 Grit, Dec 30, 2020
  14. ChapmanF
    18,537
    I've found that to be one of the things that can noticeably vary between regions, or even between highways within a region.
    When I was in the Detroit area, I noticed each highway kind of had its own culture. I-275 northwest of town is where you pretty much had to hit 10 or 15 miles over by the end of the entrance ramp or you'd just never successfully enter.
    Ford Fwy in midtown was where entering drivers never believed in merging. Every rush hour it would be brought to complete standstill by entering drivers racing around each other to the very end of the ramp, having to stop, and then stopping everyone to horn their way in. Occasionally a commercial truck driver would pull to the right to block one of them and it was a beautiful thing.
    I've noticed regional differences in the advisory speeds (yellow signs) for upcoming curves also. Where I am most used to driving, midwest and east, they are conservative; with good weather and dry pavement, you can usually assume 30 or 40 percent higher (percent, not MPH!) will be perfectly comfortable.
    Find a similar curve advisory on, say, 17 north of Santa Cruz, and the advised speed pretty much means what it says.
    I've also found a large effect of driver perspective. I had a significant shift of driving habits in my early 30s, from being a habitual speeder (it was kind of part of my identity) I sort of went cold-turkey and often set the cruise right at the posted limit. What I've noticed in the years since then is there are usually some people passing me (no problem, that's why they have lanes for that) and also, sort of amazingly, still quite a lot of people I pass (again no problem, there are lanes I can use for that).
    Back in my always-a-speeder days, I would probably have sworn up and down that I was necessarily keeping up with traffic and it would be crazy to drive the limit, with every other driver blowing my doors off. That honestly was how I perceived it at that time. It was kind of eye-opening to see by how much I had misperceived that, once I was driving nearer the posted limit.
  15. Mendel Leisk
    41,898
    I keep thinking of a hospital emergency department:
    “Engine shaking and losing coolant? Take a number; the waiting room is over there.”
  16. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    There are large segments of highway out here in Central Texas where 80mph IS the speed limit...the actual, honest to goodness official speed limit. And you'll STILL get passed like you're sitting still.
  17. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
    I was always wonder why the speed limit is so low in the US. Everyone is driving, car seems to be part of the culture - as I see it from here. In Hungary we have cars that can pass 80 mph only in the last 30 years, but that’s the speed limit for quite some time.
    (And hardly anyone goes below 90 mph.)
  18. Hitchhikin Taz
    North Carolina
    2014 Prius v wagon
    Sealant? I'm still looking for solutions here.
  19. ASRDogman
    7,818
    3,982
    Because people don't know how to drive at those speeds.
    But they think they do.
    And when there is a wreck, it's horrible and usually involves dozens of vehicles.
    I saw that in germany...
    Plus, it's a control thing. If there is no speed limit, how will the highway patrol make any money?
  20. ChapmanF
    18,537
    To say nothing of that air drag following the cube of velocity thing.
