Overheating or 12 volt battery?
Discussion in 'Gen 2 Prius Technical Discussion' started by shells2skis, Oct 23, 2016.
  1. shells2skis
    shells2skis Junior Member
    51
    AZ
    I can't figure out why my prius reset trip a and b back to zero. Also, reset reverse to beep on. Thought it was battery but did the diagnosis and battery came up good. Any thoughts? No warning lights came on just reset everything. Drove 109 miles then parked for approx 45 mins then another 109 miles. Parked for about an hour then went to drive and everything zeroed out when I started it.
  2. AzWxGuy
    AzWxGuy Weather Guy
    982
    495
    Tucson, AZ
    2021 Prius
    Did you lose your radio presets and driver door auto up setting too? You might want to remove the 12V battery and have it load tested at your favorite local auto parts store just to be sure. I don't think overheating, as in ICE overheating, would cause a voltage drop and reset.
  3. Mendel Leisk
    38,709
    How did you test the battery? How old is it too?
    #3 Mendel Leisk, Oct 23, 2016
  4. shells2skis
    51
    AZ
    Yes I lost both. I will take it and have the battery tested. Thanks.
  5. shells2skis
    51
    AZ
    I tested the battery with the self diagnostic system in the dash.
  6. shells2skis
    51
    AZ
    I bought the battery august of 2014. It's an optima with a 3 year warranty.
  7. shells2skis
    51
    AZ
    I tested with the self diagnostic in the dash. Bought the battery august of 2014, it'sa optima with a 3 year warranty.
  8. shells2skis
    51
    AZ
    Yes, I lost both. How would I check to see if voltage dropped?
  9. Mendel Leisk
    38,709
    You could try measuring the battery's voltage directly, with the car off, with a digital multi meter. You can get a cheap one for around $20. If you do, please post the voltage reading.
    It's not that old, but there's a lot of factors that might impact it's life. A door left open, or just regular infrequent use.
    The next step up in testing would be a digital load tester, Solar BA5 for example. They're kinda pricey, but any reputable battery retailer is likely to have a nice pro version of such a reader, and would be willing to show you the results. A battery might show semi-decent voltage (12.4~12.7) but still be "impacted", ie: not much potential in reserve. This can be referred to as Cranking Amps or Cold Cranking Amps. The Optima battery should have a rating for one or both of those, on top of the case, and the digital load testers can see how they compare to the published ratings. They'll typically come out with a verdict, one of the following:
    1. In good shape
    2. Decent but in need of recharge
    3. Time for a new one :)
    All the symptoms you're having point to a flakey battery, btw.
  10. shells2skis
    51
    AZ
    Alright. Thanks.
  11. shells2skis
    51
    AZ
    So now the check engine light just came on.
  12. shells2skis
    51
    AZ
    I ran the self diagnostic by having the car in ign on but not ready and pressing and holding the info button while cycling the parking lights on and off 3 times. This is the results:
    LAN Monitor EMV:
    01-DB 190-C7-F
    01-D5 190-27-8
    01-DB 110-20-8
    LAN Monitor Audio
    01-DD 110-6D-2
    LAN Monitor G/W
    01-DC 110-6D-5
    01-DD 110-6D2
    Anyone know what this means?
  13. dolj
    dolj Senior Member
    7,648
    3,858
    Wellington, New Zealand
    Nothing useful about why the MIL (message indicator light) came on. You need to have the DTCs (diagnostic trouble codes) read to determine why the MIL came on.
    Have you had your 12 V battery tested as previously advised in earlier posts?
  14. bisco
    49,446
    also check the battery connections, and where the negative cable attaches to the body.
  15. shells2skis
    51
    AZ
    Had the battery checked 12.58 and under full load 12.55. What would make it charge instead of an alternator?
  16. shells2skis
    51
    AZ
    Had the battery checked. 12.58 and 12.55 under load.
  17. Mendel Leisk
    38,709
    That's not bad. Just voltage, not a load test, that will show the battery's actual CCA. But still, a battery showing almost 12.6 volts should be ok.
    I use a Solar BA5 prosumer level tester, they're around $60 I think? Again, a decent battery store should have that sorta tester's big brother.
  18. bisco
    49,446
    it is charged by the inverter/converter from the hybrid battery when the car is in ready.
    you checked the battery, but that doesn't mean you don't have a loose connection.
  19. shells2skis
    51
    AZ
    How would I check for a loose connection? When I reinstall the battery, just make sure everything is tight?
  20. bisco
    49,446
    exactly, and clean. the connection from negative to chassis is especially important.
