Overheating
Discussion in 'Gen 2 Prius Main Forum' started by Bravojoe, Jun 24, 2024 at 6:54 PM.
  1. Bravojoe
    Bravojoe Junior Member
    Conroe Texas
    Hello I have a 08 Prius with 420,00 the car keeps overheating and can't find the leak took out the radiator inspected everything looks good also pressure tested to 25 psi and not a drop came out. But I keep getting check engine light with code p1150 and I think 1151. Has anyone had problem with air getting in through the storage tank pump? The pump still works I know because I jumped the relay to purge the system and I heard it come on and it sucked the coolant down the funnel when I jumped the relay I only get the code/check engine light when I start the car in the morning I erase it and it and it doesn't come back until the next morning or when I turn off the car for an extended period of time. This is the only thing I can think of that is causing my car to overheat it is pushing coolant through the reservoir tank.
    Thanks for any help also the water pump and thermostat are brand new as well as all the other pumps.
  2. ChapmanF
    15,399
    'overheating' doesn't have to mean there's a leak. Writing "the leak" sounds like you do think there is one. Is the level going down?
  3. Bravojoe
    Conroe Texas
    Yes the level is going down it is pushing coolant through the reservoir tank. I meant to say air leak through the pump and code 1150
  4. Bravojoe
    Conroe Texas
    Can you still get the code 1150 even if the pump is working? Do y'all think I just still have air in the system?
  5. Tombukt2
    Tombukt2 Senior Member
    8,860
    1,543
    Durham NC
    Not if the coolant level's going down sure it's filling up the void I mean how much cool did you put in from your gallon container when you go to fill the system that's your end all be all guide right there pretty much. Usually I sit there and fill the system at a trickle and comes up the neck sits at the little hole that goes to the reservoir tank tube and then all of a sudden you see air bubbles suck it down to where you can't see coolant I feel it back up to the neck again and then see the glub glub and four more in and keep doing that until it no longer drops It's literally stops at the top of the filler neck by stand there for 10 minutes now nothing will happen now I fill up the jug where I supposed to have it and then I put a little more in the radiator neck to make it run into the tube for the jug and then cap it in my '09 and 45 days I'll be able to repeat this process and I can find no coolant anywhere. I thought with the coolant heat storage tank it could be the temp sensor too in that system there's one on the side of the tank I'm sure you can test it. You said you have the pump running by jumping it so it should be working there's also a test where you can come out 4 hours and 45 minutes after the shutdown you initiated that many hours ago wait 15 minutes and at the fifth hour you should hear the pump come on to sample the temperature in the CHS tank and then it turns right off that to me would prove that the pump is working generally like it's supposed to and the call the sample at 5 hours is working I believe this information is in the factory manual.
  6. Bravojoe
    Conroe Texas
    Okay I'll bleed it again tomorrow morning. Thanks for your help.
  7. Bravojoe
    Conroe Texas
    I put about a gallon and a half in because I took out the radiator out to inspect it see if I can find a leak you can't really see the radiator through the fan shroud. I'll keep a tab now.
  8. Tombukt2
    8,860
    1,543
    Durham NC
    You are definitely in a place where the system is going to be put to the test for sure Conroe Texas is no joke but the Prius should survive down there quite well it does very well in the heat You just need to make sure you're running the air conditioner so that your battery can get the coolest air going to it after you're finished with it cooling you off that is If you don't have air conditioning this could be potentially a big problem in the Big heat of Texas absolutely If you can't get that fixed like it needs the evaporator replaced well you're going to either have to slow down or get another car or shell out the three grand to fix the evaporator those are pretty much your choices Yaris and Corolla have come down since the pandemic I see them all over the place they do quite well in the heat and the Yaris almost gets the gas mileage of the Prius with no batteries no silly business just sensible driving and windows up and air conditioning on.
