Oxygen Sensor issues
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by d_w, Mar 7, 2025.
  1. d_w
    d_w New Member
    Hey all,
    My 2007 is throwing a p2195 code and occasionally a p0138. MPGs have dropped to low 30s. There is something up with the O2 sensors, so I am trying to narrow down the issue.
    I recently did a piston soak to help with an oil burning issue. Replaced the PCV, spark plugs, and valve cover gasket. Cleaned the MAG sensor. It all went well, I don’t *think* these codes are related.
    I’ve attached a log of a short city drive between 30-40mph. The A/F sensor data seems erratic to me, as well as the short term fuel trim.
    I have a replacement A/F sensor on order, but was looking for more opinions before changing out the part. Is there anything else it could be? Am I missing something? Any help is greatly appreciated.
  2. d_w
    d_w New Member
    Here is another short trip log, mostly at highway speeds
  3. dolj
    dolj Senior Member
    8,446
    4,291
    Wellington, New Zealand
    Did you mean MAF sensor? Did you clean both the temperature sensor (at the side of the 'finger') and the airflow sensor (embedded inside the 'finger')?
    Did you disconnect the 12 V battery for a minute or two after you did all the work? You need to do this so it resets the EMC to defaults. Especially import after cleaning the MAF/throttle body.
  4. d_w
    d_w New Member
    Yes, the MAF. Typo. Everything on it got a good clean. I did disconnect the battery to reset the ECM but didn’t see any differences before and after.
  5. dolj
    dolj Senior Member
    8,446
    4,291
    After a reset, it takes several drive cycles for the ECM to relearn the optimum values. Anything from 5 minutes to 5 days.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,047
    1,974
    NJ-USA
    Do you have freezeframe data for either code? It's a bit odd because P2195 is for the B1S1 Air-Fuel ratio sensor stuck lean. That should show in data as at or near 5.0V. Short Term Fuel Trim should go positive to compensate.
    Your graphs show (unexplained) dips in A-F voltage down to 1.4V, that's indicating (or at least reporting) a rich condition, and STFT is going highly negative in response.
  7. d_w
    d_w New Member
    I’ll post the FF data when I drive a bit more and the code pops again (I recently cleared the codes). I am also confused by the data coming off the sensors as it isn’t really logical.
  8. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    Short term fuel trim means that the gasoline is flowing like a river and screaming to the engine computer "Stop it".
    And the gasoline supply is reduced. The engine growls, but moves. You press the gas pedal again and everything repeats.
    Everything needs to be checked again, spark plugs, coils, fuel supply, injectors, air supply, etc.
  9. mr_guy_mann
    4,047
    1,974
    NJ-USA
    Close. But you have to be careful about assumptions or they will kick your butt.
    Short Term Fuel Trim is a response to the upstream S1 Air-Fuel (or oxygen) sensor.
    If the S1 reports a rich mixture, STFT makes a negative correction to reduce fuel. If S1 reports lean, then STFT makes a positive correction to increase fuel.
    There are three general areas that can cause fuel trim problems.
    First is an input sensor misreporting that results in the wrong base injector on time. (Think dirty MAF or a vacuum leak).
    Second is a fuel delivery fault. Fuel pump, clogged injectors, even the wrong fuel in the tank.
    Third is that the A-F or O2 sensor is lying. This is also an ECM input, but I keep them separate because it can really trip you up.
    MAX2 likes this.
  10. d_w
    d_w New Member
    The codes popped again, luckily while I was recording a log. P2195 and P0138. In the logs, it is easy to see when they triggered about halfway through where the A/F sensor spikes up and the O2 sensor drops to 0.
    It doesn’t have freeze frame data for the p2195 code, just p0138 for some reason, but they seemed to happen at the same time so hopefully that is relevant.
  11. mr_guy_mann
    4,047
    1,974
    NJ-USA
    No, it's the other way around. If you try to line up the RPM graph (by frame numbers along the bottom, around 225-250), the A-F goes high (lean) and O2 goes 0 (lean) when the RPM hits 0 (engine off).
    It would be a little easier to correlate things if you ditched vehicle speed. Right now some of the graphs have different scaling.
    P0138 is the S2 O2 voltage going too high. That can be 1V or more, OR it can be around 100mV higher than normal.
    The freezeframe data doesn't really show anything abnormal. Fuel trim is slightly high but S2 O2 is at 0.7V. Whatever happened, FF didn't catch it.
    However, look earlier at the data graph around frame 130(?), you have a hard accel from around 25mph. Again the S1 A-F sensor goes crazy low voltage (rich), and this time the S2 O2 hits 1V, also full rich. That is likely where it set P0138. Both sensors reporting rich suggests that it's true. Wonder what the MAF reads?
    Some cars go full rich during WOT acceleration, but I don't think the Prius is one. Will have to check on my commute home.
    #11 mr_guy_mann, Mar 11, 2025
  12. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    You will have to start working by the process of elimination.
    Another CEL Thread!!! P0138 and P2195 | PriusChat
  13. d_w
    d_w New Member
    More data from today. Codes came up on an acceleration at about the 300sec in the logs. Freezeframe is for the p2195 code, it peaked at 5V while the O2 sensor dropped to ~0
  14. d_w
    d_w New Member
    That thread was my initial troubleshooting, I have done / checked everything up until replacing the A/F sensor. Wanted to see if there was something notable about my case before spending the $ on the new part.
  15. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    If you checked everything according to the manual and nothing happened, then all that remains is to change the parts.
    https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/2054m/cip2195.pdf
  16. mr_guy_mann
    4,047
    1,974
    NJ-USA
    Nothing stands out in what data I see. It always looks plausible that every "lean A-F & O2" reading occurs when the engine is stopped (0 RPM) or "spinning" (1000 RPM but not running).
    Given that previous data graphs also have unusual rich (low voltage) spikes, I would put in a S1 A-F sensor and see what happens. Toyota or Denso from a reputable source. (not eBay, amazon etc).
  17. d_w
    d_w New Member
    Installed a new A/F sensor yesterday. Will report back with a resolution if it is solved or it comes back.
  18. ChapmanF
    18,204
    I'm sure if they do it on purpose, they don't then set trouble codes about it.
    Back in the day, excessively-rich-just-at-WOT might have made me take a close look at the air filter. Not sure that still holds in a car with a MAF sensor, but I'd probably still look. Hard habit to break.
  19. d_w
    d_w New Member
    Forgot to post the old vs new sensor pic. Old one has seen some shit.
  20. d_w
    d_w New Member
    Final reply to confirm A/F Sensor replacement did the trick. No issues after 100 miles of mixed driving.
    Brian1954 and mr_guy_mann like this.
