Oxygen sensor problem
Discussion in 'Gen 2 Prius Technical Discussion' started by Giorgi Avalishvili, Nov 23, 2024.
  1. Giorgi Avalishvili
    Giorgi Avalishvili New Member
    Georgia country
    Hello guys.
    I have downstream oxygen sersor problem changed the sensor deleted all codes (p0136 p0137 p0138 p0139) and removed check light.
    After driving 50miles check light come back and now it showing p0136 and p0137 codes but the oxygen sensor is brand new.
    What can be problem? There is something i cant see?
  2. Brian1954
    Brian1954 Senior Member
    1,703
    664
    South Central PA, USA
    You could have a wiring problem or a leak in the exhaust system.
  3. Giorgi Avalishvili
    Georgia country
    I see the issues what can cause this codes but exhaust system not have leak and also wires are in good condition
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,939
    1,900
    NJ-USA
    What voltage do you see on your scantool for the downstream oxygen sensor? Check at different conditions while the engine is running.
    What brand of sensor was installed? I only use a Toyota or Denso from a reputable source.
  5. EternalPrius
    EternalPrius Junior Member
    Pasadena, CA
    Three Touring
    Is the cat aftermarket or oem? I had this problem shortly after installing a cheap aftermarket cat on ebay
  6. Giorgi Avalishvili
    Georgia country
    Its just taiwan brand i dont know its voltage
    I have ford fusion hybrid cat and its so good i checked one day ago
  7. Giorgi Avalishvili
    Georgia country
    I am not in usa i am in country georgia and where can i buy it?
  8. Giorgi Avalishvili
    Georgia country
    This is downstream oxygen sensor checks u can see also voltage
