Oz Green Vehicle Guide
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by kenmac, May 12, 2005.
  1. kenmac
    kenmac New Member
    149
    Perth, Western Australia
    Hi folks,
    The Oz Government has recently upgraded the Prius to #1 in their Green ratings.
    Check this link for the database list Green Guide
    Select "Search...database" and Medium vehicle.
    kenmac
    edited 13/5/05 Link data
  2. NuShrike
    NuShrike Active Member
    1,378
    The Green Guide link seems to be broken.
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
  4. NuShrike
    1,378
    Tried your links; nope. The guide is probably session specific so you can't directly link to it. Try copying your link into another browser (IE if you're using Firefox; Firefox if you're using IE) and see if it works. That's what I do to test for session-specifics.
  5. Godiva
    Godiva AmeriKan Citizen
    10,339
    Hmm. I truncated the URL and then did a search for the Prius.
    Their info was for the 2003 even though I specified current model.
    They're a little out of date.
  6. kenmac
    kenmac New Member
    149
    Sorry about that link folks.
    However here is the Home Page.
    From there you can select "Search ... database" , selecting Medium size.
    The data is the latest rating, having just been updated according to local press.
    Governments are not noted for quick reactions to the obvious.
    kenmac
  7. aussie
    aussie New Member
    17
    the current prius was released in Australia in october 2003
  8. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    Okay, I followed the link, did a search and...where are the Hondas? Are they not sold down under?
    I had to display the top 200 and the Honda Jazz showed up. What gives here? Are they not as green as Honda says they are?
    I knew they were not quite Prius level (at least outside of Calif, and the NE states), but...wow. Am I missing something here.
    ...and on the back of this months Sierra Mag, Honda has a big ad for how green they are...hmmmm...apparently not in Australia!??
  9. kenmac
    kenmac New Member
    149
    I checked with the database owners - they said Honda Insight is no longer sold in Oz, but the Honda Civic Hybrid is.
    I found the Civic in the database - it is somewhat lower because of lower pollution ratings but is near the top if you list in order of fuel consumption.
    kenmac
