Ozone from Electric Motors?
Discussion in 'Environmental Discussion' started by Tideland Prius, Apr 26, 2006.
  1. Tideland Prius
    16,128
    Someone brought this up in another forum as a hybrid negative. He said electric motors produce ozone and that the larger motors in the Prius will negate the benefit of reduced CO2 emissions.
    Thoughts?
  2. unruhly
    unruhly New Member
    205
    My initial thought is that ozone is created by a high voltage spark gap which occurs in motors that have carbon brushes and armatures (like a drill motor).
    If I'm not mistaken, permanent magnet motors do not produce ozone since there is nothing more than a magnetic field being induced and collapsed at timed intervals.
  3. naterprius
    naterprius Senior Member
    1,843
    Well, then, I'm trading my Prius for an Escalade. Can I get with a carburetor so the solenoid motors in the fuel injectors don't release ozone?
    Nate
  4. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    so we are saying that ozone is bad for us???
  5. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
  6. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
  7. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Dave,
    Ozone in the lower atmosphere is a bad thing. Scars lung issues, etc. In the lower atmosphere NOx and CO and HydroCarbons work with UV radiation to create O3 (ozone). Ironically, in the upper atmosphere (where Ozone is a good thing) NOx detroys ozone because the atmosphereic pressure is lower. Oxygenating gasoline helps reduce NOx and CO emissions.
    I don't know about the electric motor issue. Sounds like unruhly has an answer though.
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Brushless motors, such as the ones on the Prius, don't make ozone. You need a high voltage spark for that, as was already mentioned in a previous reply.
    Tom
