p lock malfunction when parking
Discussion in 'Gen 3 Prius Main Forum' started by Zack95959595, Nov 22, 2019.
  1. Zack95959595
    Zack95959595 New Member
    Hello i got in car accident and the car just stopped functioning or do anything when I press on the start button it shows this message and I’m not able to put the transmission on parking or anything what can be the issue I tried to take off the 12v battery and reconnect it but nothing happened
  2. AzWxGuy
    AzWxGuy Weather Guy
    979
    495
    Tucson, AZ
    2021 Prius
    Was the vehicle repaired? How long between collision and repair? Most if not all P-lock codes are an indicator of 12V battery problems. Chances are the wreck crossed up some wires and drew down the state of charge. If the battery is original 2012 then age is contributing to low state of charge. You should remove the 12V battery and have it bench tested with load, which a car parts place will usually do for free. After determining whether the battery needs to be replaced I would then have a parasitic draw test performed on the vehicle to insure there are no more electrical shorts.
  3. Zack95959595
    The car still at the repair shop they are not able to figure out the issue but the main problem is the transmission is not responding at apl
  4. BZzap!
    BZzap! Senior Member
    1,607
    877
    Is it a body shop that’s trying to diagnose the problem or a qualified vehicle repair facility? If, whoever is try to fix it doesn’t have the technical expertise and doesn’t understand the theory of operation, they are, so to speak, pissing up a rope. You need to talk to your insurance rep. and have it inspected and diagnosed at a dealer or someone who knows what they are doing.
  5. bisco
    49,397
    tmr-jwap did a write up on his diagnosis. it was very complicated
  6. emge
    emge New Member
    I was wondering if you got a chance to find a solution. I have the same issue.
  7. Johnny Cakes
    Johnny Cakes Senior Member
    1,010
    761
    Virginia, USA
    Clicking on his icon reveals: "Zack95959595 was last seen: Nov 23, 2019"
  8. emge
    emge New Member
    Thank you! Just joined yesterday, I should pay more attention to that :)
  9. nicoj36
    nicoj36 Active Member
    495
    158
    Try this.
    Put the e-brake on all the way. Turn on car by pressing power twice (don't start). Put the car in neutral. Then start the car while in neutral. Let us know if it works.
