"P" Lock Mechanism error code ???
Discussion in 'Gen 2 Prius Main Forum' started by 2008Prius777, Jan 15, 2017.
  1. 2008Prius777
    2008Prius777 Junior Member
    West Palm Beach, FL
    Hello, I had an incompetent mechanic replace my AC converter, removing all the dash and when putting it back together, I now have this error code locking the parking brake and not allowing the car to start. Does anyone have any idea on what's the issue. I need to have someone go back into the dash and make sure all was put together correctly but need to have an idea of what this error code likely means. Thank you!
    49,587
    can be something as simple as a bad 12 volt battery, or loose hatch locking mechanism.
  3. b100
    b100 Member
    141
    73
    Netherlands
    Put the connector behind the P button back.
  4. Amber_1
    Amber_1 New Member
    What was the resolution to this? Any update? I know it’s an older thread but I’m curious mine is doing the same
  5. bisco
    49,587
    welcome!
    did an incompetent mechanic replace your a/c converter?
  6. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    He may have forgotten to connect the lock mechanism connector on it while assembling.
