P LOCK Problem ? Causing a Starting Problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DCM, Mar 26, 2015.
  1. DCM
    DCM New Member
    East Wakefield, NH
    In the past month the P Lock malfunction (07 Prius) indicator light has come and stayed on. Twice in the past month after going into a store it would not start. After waiting around 5 minutes and pressing the start button a bunch of times it finally started. The battery reads 12.17 volts. I disconnected the battery to see if it would reset the malfunction indicator. It did not and I am worried one of these days it won't start at all. Any suggestions?
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    That error message is a classic low 12V problem, as is your startup problem. Either fully charge the battery, and make sure the connections are tight, or replace it now if it is old. Your reading of 12.17 volts does not give any confidence in the viability of the present battery.
    49,732
  4. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    To put it another way, the P Lock problem isn't causing the starting problem--they're both symptoms of the battery condition.
  5. DCM
    DCM New Member
    East Wakefield, NH
    That's what I've been reading which is why I checked the battery. Sounds like any kind of load may be dropping it under 9 or 10 volts. The battery is 8 yrs old. Will change it and see what happens. Thanks!
