P0016 Troubleshooting, possible misfires(?), & some Techstream screenshots
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jss4837, Jan 28, 2025.
  1. Jss4837
    Jss4837 New Member
    Springfield, MA
    Hey! I'm not a car guy, so just looking for some general advice & suggestions based on my situation. Not sure if this was the cause or related, but I recently neglected to check my oil for a few months - when I did it was below the dipstick, but I never got a low oil pressure warning or anything and adding just like 0.2 quarts reached up to the end of the dipstick, so I don't think it was entirely empty - But at that same time I encountered the P0016 error code. I cleared it about 5 days ago and now it has popped back up.
    I have Techstream on an old laptop but I have no idea how to really read the data it is showing me, so I screenshotted some of the freeze frame data and included it here if anyone can gather anything from it. I'm sure this error code needs actual physical diagnosis so I am going to be taking it in ASAP, but just thought I would see what people think here. Should I be worried about these "EWMA" misfire counts? No idea if that is a separate issue or related to the error code.
    Also, would you guys take this code to a regular mechanic, or a hybrid specialist? I found this shop" Hilltown Hybrids " about an hour drive from me which has good reviews and are willing to look at it (with a $150 diagnostic cost), or alternatively, my regular in-town mechanic usually doesn't charge for diagnosis (or maybe just includes it in service cost) but he is not necessarily a hybrid specialist. He said he has dealt with this error code on other cars before but not yet on a Prius. I'm just a broke college student who wants his car to last, so any advice is welcome. What do you guys think?
    Thanks for reading!
  2. Tombukt2
    Tombukt2 Senior Member
    11,937
    2,109
    Durham NC
    Maybe it's been a while since an oil change or it's coming to oil change time I think the code that you're showing here is the code that has to do with the camshaft and the crankshaft sensor not being in sync meaning the timing chain is stretched My gold 09 does this only with dirty oil soon as I change out the engine oil the code goes away on its own and I have been running 10,000 mi oil changes on that vehicle for a long time and it's at like 400,000 mi so it's highly likely that the chain is getting worn and all of that but I noticed when I change the oil everything seems to be fine so we'll keep doing that till it's not I think that's the code you have right now so maybe try changing your oil before you start paying diagnostic fees unless you clearly can see some plugs undone on your car which I highly doubt unless something's recently happened..
    Jss4837 likes this.
  3. Jss4837
    Jss4837 New Member
    Springfield, MA
    No sure what you mean by "plugs undone" to be honest, but the car seems to be running normally, and I'm getting my usual 40-43mpg that I've always gotten if that means anything. Also, I did change the oil myself just like a week ago. I think the code may have gone away last night actually unless I accidentally cleared it when messing with the scanner, but I don't think I did. Yeah, it's tricky, I don't want to spend money on diagnostic fees, but I also want this car to last me for a while, so I don't want to drive it too much with this code if it could potentially damage the engine or something.
  4. MAX2
    MAX2 Senior Member
    1,436
    481
    101
    Third planet from the Sun
    Error P0016 signals the driver that there is a discrepancy in the position of the shafts. This code pops up when the data from the crankshaft and camshaft sensors (DPKV and DPRV) do not match, that is, the angular position of the camshaft and crankshaft relative to each other deviated from the norm.
    On older engines the chain may be stretched. See the manual on how to check.
    https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/2054m/cip0016.pdf
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,936
    1,898
    NJ-USA
    As mentioned, this code has to do with the rotational position of the camshaft when compared to the crankshaft. The camshaft isn't where the ECM (engine computer) expects it to be.
    The engine uses Variable Valve Timing - it can (slightly) shift the cam relative to the cam sprocket.
    Best case for you is that the solenoid that controls VVT is stuck (inadvertently shifting cam timing - that should set a different code but sometimes doesn't ). Worse would be that the timing chain is worn and stretched.
    As far as engine work, there's nothing much special about the Prius 1.5L. If your local guy is good, then go there.
    Brian1954 likes this.
  6. Jss4837
    Jss4837 New Member
    Springfield, MA
    Update: I haven't had it looked at yet, but I noticed the check engine light seems to go on and off. The code persists either way, but the check engine light seems to stay on for a bit, then randomly when I start the car it will be gone. Does this mean that it's like a pending code or something?
  7. highmilesgarage
    highmilesgarage Active Member
    425
    151
    Kansas City
    if it's only P0016 and no other codes, it will be almost certain that it's a stretched timing chain. Try driving it harder like full acceleration and then slowdown and repeat the process, then switch to "B" mode and drive it aggressively. The code will become permanent over time.
  8. Jss4837
    Jss4837 New Member
    Springfield, MA
    Thanks for your reply. Dang, that is unfortunate. What should I be looking for when driving it harder like that - just for the code to become permanent, or for unusual driving behavior of some sort? And for next steps, what would you recommend doing with this car at this point, assuming it is likely the timing chain. Is it worth getting the engine rebuilt to replace the timing chain, better to replace the whole engine with a used one, or ditch the car altogether? I cannot afford another car really so repair would be preferable. I talked with my regular mechanic about this for a bit, and when he quickly looked up timing chain parts and labor costs, he said it would probably be a little under $2k to replace it. I may take the car to a hybrid specialist that is about an hour away from me, but not sure if that is even worth it since this code seems to be just a general engine issue. I just figure maybe a hybrid specialist could pinpoint the exact cause more accurately, but I really don't know what to do.
  9. dolj
    dolj Senior Member
    8,164
    4,161
    Wellington, New Zealand
    What does "switching to "B" mode" do, in this scenario?
  10. highmilesgarage
    425
    151
    Kansas City
    "Bitch mode" - it will activate the vvt often at lower speeds (below 50mph) If you have a failing vvt solenoid it will also pop up quicker when doing this mode.
    Skiddmore likes this.
