P0031 code
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by priusde, Aug 27, 2017.
  1. priusde
    priusde Junior Member
    28
    DE
    I have the P0031 code and from what I've found points to the A/F ratio sensor Bank 1 Sensor 1. I found the part number I need is Denso 234-9090. Is this something I could do myself or is this a job left to the dealer due to the location of the sensor not being very accessible? Would I need special tools?
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    The Air fuel ratio sensor heater is by the EGR pipe and cooler. You will need an O2 sensor socket to remove the sensor though.
  3. priusde
    28
    DE
    Do I follow your EGR pipe cleaning video to access?
  4. NutzAboutBolts
    1,476
    1,552
    Bay Area
    you can try, I haven't taken a look at it yet.
  5. m.wynn
    m.wynn Senior Member
    684
    1,226
    Queensbury, NY
    It's on the exhaust manifold. You can see it by standing at the passenger side front fender, putting your face behind the engine coolant bottle and peeking behind the top end. Flashlight helps. Follow Nutz about Bolts video (spark plug change, maybe?..) that shows removing the wiper cowl and access becomes about as easy as could be. You may be able to get at it from underneath with the convoluted under tray off, but removing the wiper cowl is the way to go. You'll need an O2 sensor socket, and since the A/F sensor has the stupid collar, will likely have to grind the socket down some in order to fit within the collar. Or you can buy the factory Toyota O2 socket for a ridiculous amount and skip the grind work.
    If the car is ready for spark plugs or EGR circuit tear down and cleaning, now's a good time with the cowl off...
    Good luck.
    NutzAboutBolts and Raytheeagle like this.
  6. priusde
    28
    DE
    Thanks m.wynn. Will take a look at nutzaboutbolts spark plug replacement video to remove the wiper cowl.
    NutzAboutBolts and m.wynn like this.
