P0117 coolant sensor temporary workaround??
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rrrolfff, Apr 8, 2022.
  1. Rrrolfff
    Rrrolfff Junior Member
    77
    Irvine
    I unfortunately have the dreaded head gasket leak - which caused my coolant to go very low - thankfully the engine still runs, I put in coolant, and get a coolant reading on Torque Pro, but the sensor seems to stop working once it warms up.
    Anyone with experience swapping this crazy thing? It seems to be a super hard project, but I'm short on money right now
    As always any help is appreciated!
  2. ChapmanF
    15,558
    If you for sure have a head gasket leak, then by "swapping this crazy thing" you mean swapping the head gasket, I hope?
    Swapping anything else would be rearranging deck chairs ....
  3. Rrrolfff
    77
    Irvine
    Not really - an engine rebuild / head gasket costs far more than a $20 sensor. As can be seen in many posts, the known engine failure does not stop the car from running. It causes some engine knocks at start (which I rarely see).
    The sensor seems to be running ok after bathing in coolant for two days (eg it was pretty dry when the coolant was 4 qts low - now after 2 days, it's running).
    Now the heater is not functioning
  4. ChapmanF
    15,558
    Of course not. Silly me.
    CR94 likes this.
