P0121 - Throttle Body / TPS Sensor failure - Remedies?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mavi, Feb 14, 2017.
  1. Mavi
    Mavi Active Member
    484
    284
    San Diego,ca
    2020 Prius Prime
    So I got a P0121 code which basically means the TPS sensor has gone bad, my car starting stalling, but not enough to stop, until at one point the engine shut off, the battery drained and I had to turn off the car and turn it back on after 10 minutes to get home very slowly.
    Is there anyway to just change the TPS sensor with something like this:
    NEW Genuine OEM Toyota Throttle Position Sensor 89452-35020 TPS Japan Made NIB | eBay
    or will I have to pick up a whole used throttle body system and change that out?
    Note: I did clean out the MAF and throttle body regularly with their own respective cleaners.
    Thanks
  2. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,136
    1,573
    Iowa
    The fount of all Prius Knowledge here -- other than me, of course --
    Patrick Wong says the TPS is not replaceable. You have to replace the whole thing....see this thread -- his post is #4.
    throttle position sensor | PriusChat
    #2 cyberpriusII, Feb 14, 2017
  3. Mavi
    Mavi Active Member
    484
    284
    San Diego,ca
    2020 Prius Prime
    Perfect, searched around through googles search and couldn't find that thread. Thanks
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    "Does it hurt when you do that?" "Then don't do that!"
    There is no hint that Toyota recommends that
  5. Mavi
    Mavi Active Member
    484
    284
    San Diego,ca
    2020 Prius Prime
    Issue fixed by picking up a used throttle body with tps and a gasket for ~$50 from ebay and swapping them out.
    A.J. Tarnas and cyberpriusII like this.
  6. cyberpriusII
    1,136
    1,573
    Iowa
    Thanks for the UPDATE!!!
  7. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    746
    Delaware
    some folks recommend that to clean the throttle body, DON'T spray the cleaner into the throttle because it will get into the tps and damage it. instead spray a lint free cloth and wipe the crud out from around the throttle blade.
    A.J. Tarnas likes this.
  8. Mavi
    Mavi Active Member
    484
    284
    San Diego,ca
    2020 Prius Prime
    That's what I usually do. The car's last cleaning was like 15k miles ago and then randomly threw this code after cutting out in the highway. Just it's time to go im guessing.
  9. Steven Parizeau
    Steven Parizeau New Member
    Kauai, Hawaii
    Thanks for the update! I’m having this issue right now (9-10-2021).
    What was the part number of the replacement unit that you got?
    that link you posted brought me to Walmart search for “throttle body” just not sure which one you were referring to.
    How long did the replacement take?
    Thanks for the help so far!
