P0125 & P0A80 Engine won't work
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius2dt0, Feb 25, 2019.
  1. Prius2dt0
    Prius2dt0 New Member
    Shirley, New York
    Hi everyone!
    Could somebody recommend good trouble shouter to resolve problem with my Prius 2007: Engine work few seconds and stop. Light many errors. "Ready" not light. Error reader show P0125 and P0A80. In diagnostic display show: EMV - Chek, Audio H/U - Chek, G/W - chek. 12V Battery was changed a few months ago. Location in Long Island, NY.
      File size:
      62.1 KB
      File size:
      29.9 KB
      File size:
      64.9 KB
      File size:
      80.3 KB
  2. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
    P0A80 = HV Battery is bad.
    * replace w/ NEW for reliability or go w/ 2k1Toaser's cylindrical cell replacement kit.
    * used/rebuilt/remanufacture are a poor choice b/c the are made from old modules
    * module replacement is a band-aid fix and is NOT reliable.
    * Read Post #9&#11 to help you decide which way you want to go: Indianapolis area battery repair? | PriusChat
    * if you have to pay for labor, time for a new car or a younger used car.
    P0125 = Insufficient coolant temperature for closed loop fuel control.
    * you have a leak in the cooling system?
    * air entered the cooling system, likely due to a leak.
    * someone recently serviced the cooling system (drain/fill, replaced a pump or both) and did not bleed all the air out.​
    DDA.jpg & DDD.jpg, are images of the onscreen diagnostic menu for the AUDIO and NAV system. This will NOT affect the vehicle engine and hybrid system performance.
    Prius2dt0 likes this.
