P0138 & check engine after cat converter replacement.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MRK0017, Nov 14, 2021.
  1. MRK0017
    MRK0017 Junior Member
    ITA
    Long story short, at some point last month I got my catalytic converter stolen. I got it replaced at a local mechanic because Toyota wanted nearly 3000€ for the replacement. Anyway, a few days after the replacement, I got the check engine light. Checked the codes with a odb2 connector and it says it's P0138 (O2 Sensor Circuit High Voltage). Went back to the mechanic and he said that the sensor got damaged during the theft, and that water may have gotten inside the sensor or something like that (don't remember), and that I shouldn't worry too much and save the money. Car runs just fine and mileage seems normal to me, and sometimes the check engine light turns off on its own, but it usually comes back after a day or so.
    That being said, I don't believe this should be ignored. What do the true Prius experts think?
    Also, wouldn't running with the check engine light permanently on hide other problems that would make the light turn on, read: dangerous?
  2. MRK0017
    ITA
    Hello again everyone. All of a sudden the check engine light turned off and has been off for several days now. In the meantime, I bought another odb2 device and there doesn't seem to be any error right now. What do you think?
  3. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    If the light comes back on I would definitely replace the O2 sensor. It is very possible it got damage from the theft. At the very least do a good inspection on it and look at the wiring for the O2 sensor. Problem with running the car with the check engine light on if you don’t know When there are other problems just like you stated. I have a generation three and it does not have a temperature gauge you get a check engine light for overheat.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,053
    1,977
    NJ-USA
    Sometimes a brand new catalytic converter can work a bit differently than the engine computer expects (ie, it causes the downstream O2 sensor reading to be not spot on). It can take a week for the cat to "break in" - once it does the O2 readings settle down and now the ecm will turn the light off.
    iron-icman likes this.
  5. MRK0017
    ITA
    After the light disappeared for a few months, it came back with P0420. I think either the sensor is actually damage or the whole cat is on its way out already. Maybe he scammed me? Car still runs ok I guess, but I'm getting a bit paranoid, also it's a bit annoying to drive with that yellow light constantly looking at me.
  6. anonymous
    anonymous Member
    177
    99
    US
    maybe u got one of those fake $45 cats
  7. iron-icman
    iron-icman Member
    130
    43
    Leeds UK
    ----UK----
    I have just had mine replaced and I have the same issue and code what happened with yours.
