P0138! Front air/ratio censor not rear in most cases
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Buffmatt12, Jan 27, 2015.
  1. Buffmatt12
    Buffmatt12 Junior Member
    hey everybody I just wanted to mention the results of a CEL LIGHT issue. Recentlythe check engine light came on my 2005 Prius(162000 miles). Got the code checked and it was p0-138. every mechanic and their mother calls out the rear oxygen sensor for this code. So I replaced the rear oxygen sensor and light was still on. after digging deep I found a few people having the same issue but not posting the end result after going to the dealership. so finally I found a thread posted their end result and it turned out to be the front air/fuel ratio oxygen sensor. apparently with other makes it usually is the rear but with Toyotas it is usually the front. so sure enough I replaced the front sensor and problem solved. hopefully this can save somebody a lot of grief in diagnosing p0 138
    49,504
    well done, thanks for posting it up!(y)
    Buffmatt12 likes this.
  3. Jnkbnd111
    Jnkbnd111 Junior Member
    Philadelphia
    2002 Prius
    Can you scan both sensors in order to detect which one to replace?
