P0171 after oil catch can install
Discussion in 'Gen 3 Prius Main Forum' started by Tiff, Feb 27, 2019.
  1. Tiff
    Tiff Junior Member
    86
    Crawley
    Hi guys just installed an oil catch can.
    Got a p0171 code after the test drive which goes back to vacuum leak or pcv valve.
    Any help
  2. qettyz
    qettyz Active Member
    181
    206
    Finland
    Is oil catch can such version what have breather filter on top of it?
    If so, that should be blocked.
    jerrymildred likes this.
  3. Robertto09
    Robertto09 Junior Member
    51
    Costa Rica
  4. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Check for any loose hoses that you unplugged & slightly wiggle all connections are tightly on first. I had a catch can installed 2 weeks ago and suffered the U0100 cel code, it was an unplugged hose. So the pain is still fresh in my head.
    Bay Stater and Raytheeagle like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Could be a misaligned part or clamp too;).
    But it definitely is caused by something not being reassembled right(y).
    Bay Stater likes this.
  6. Tiff
    Tiff Junior Member
    86
    Crawley
    Yes thanks guys.
    It wasnt the breather type but had a clear tube on side to show level which was leaking. Re installed now ok.
    Bay Stater, RMB, qettyz and 2 others like this.
