P0171 - Recently replaced pistons & rings
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by djimbuser, Oct 27, 2025 at 2:31 PM.
  1. djimbuser
    djimbuser Member
    88
    31
    Henderson, Nevada
    Prior to tearing engine down and replacing pistons & rings there was no P0171 code. After getting the engine reassembled I get the P0171 on every second drive (service manual clearly states it's a two-drive code).
    What I can't figure out is why. All hoses connected. Upstream O2 sensor connected. Fittings between the MAF and throttle body have tight clamps.
    I captured the freeze frame data and attached them can anyone single out the issue on the freeze frame data?
    Thank you!
  2. PriusCamper
    PriusCamper Senior Member
    12,542
    5,081
    Pacific Northwest, USA
    Wiggle all the vacume hoses... Maybe one of them is damaged?
  3. djimbuser
    djimbuser Member
    88
    31
    Henderson, Nevada
    Wish it was that simple. All the hoses seem flexible and in good shape. I took off the air cleaner box and noticed that one of the clamps to the duct leading to the throttle body wasn't tight so I tightened that and thought maybe that was the fix but I drove it two more drives and the CEL reappeared :(
  4. Brian1954
    Brian1954 Senior Member
    2,069
    806
    South Central PA, USA
    Check the hose from the PVC valve to the intake manifold. Also, check the two hoses that I wrote about in a different thread two weeks ago which I copied below.
    #4 Brian1954, Oct 27, 2025 at 5:58 PM
  5. djimbuser
    djimbuser Member
    88
    31
    Henderson, Nevada
    I have ordered a new upstream O2 sensor I'm going to try that... That said all I did was disconnect those three connections down near bottom of timing of timing cover so I could sling the wiring harness up and out of the way during the engine work days. I'm 100% sure I've reconnected it correctly.
  6. djimbuser
    djimbuser Member
    88
    31
    Henderson, Nevada
    Oh yes I HATE that hose. Backstory on this car I replaced the head gasket a couple years ago and that hose split at the top so I cut it off and used a hose clamp. I did not have a P0171 CEL for doing that...
    Update/clarification. The hose IS connected to the top engine cover.. it's just that so little of the hose is on the nipple I thought it best to use a clamp to make sure it doesn't fall off.
  7. djimbuser
    djimbuser Member
    88
    31
    Henderson, Nevada
    I see it now.. it's the "Total FT #1" on image #2. My car doing 39% which is outside of the acceptable high of 35%... Now the question is WHY. I have new Denso Fuel injectors, new Denso coils, new NGK spark plugs, new EGR Valve, and super clean EGR heat exchanger.
  8. Brian1954
    2,069
    806
    You have a vacuum leak. Remove the air box and check the three hoses I mentioned in post #4.
    #8 Brian1954, Oct 27, 2025 at 8:13 PM
    BiomedO1 likes this.
  9. Brian1954
    2,069
    806
    That is not one of the three hoses that I was talking about in post #4.
  10. BiomedO1
    BiomedO1 Senior Member
    3,345
    1,748
    SacTown, Ca
    And it may not be a hose, but a ruptured diaphragm - same as a disconnected hose. You need to use a vacuum pump to check them.o_O:eek:
    That was week of my life that I'll never get back.:cry::whistle:
  11. Brian1954
    2,069
    806
    What diaphragm are you talking about on a Gen 3 Prius?
  12. BiomedO1
    3,345
    1,748
    SacTown, Ca
    Well, if a gen3 Prius doesn't have vacuum controlled diaphragms - forget it. I'm used to working on the really old stuff that use to have those. The rubber would get old and rupture internally; so everything looks good upon visual inspection.
    #12 BiomedO1, Oct 27, 2025 at 8:34 PM
  13. djimbuser
    djimbuser Member
    88
    31
    Henderson, Nevada
    Ok.. I'll report back tomorrow!
