P0300,0301,0302
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Kats_Pajamaz, Mar 6, 2022.
  1. Kats_Pajamaz
    Kats_Pajamaz Junior Member
    35
    ohio
    Last night my engine started misfiring and my reader gave me these codes. After a little bit of research, I am thinking my path is going to be to check the sparkplugs/coils and also see if anything is leaking into them. If that all checks out, I am going to move on to cleaning the EGR system including the cooler and the intake manifold. Does this seem like a good starting point or should I be looking into other avenues first? I am trying to go for a combination of the most likely cause, and the easiest/cheapest to do first.
    Additionally, when I went to check my coolant to see if it looked off due to leakage, it looked fine but there was also a bit of pressure release when I opened the cap. Nothing crazy but loud enough to be easily noticeable. The car has sat all night and is completely cooled off. Is that little bit of pressure normal, or is that something I need to look into?
  2. PriusCamper
    PriusCamper Senior Member
    13,065
    5,306
    Pacific Northwest, USA
    That sucking sound is a sign of coolant loss into the engine due to bad head gasket. However, some folks can go a couple years with that problem if its minor and they use the vehicle sparingly.
  3. Mendel Leisk
    41,905
    Do you’re coil check just by moving them around: your codes indicate misfire on cyl’s 1 and 2. Swap those with 3 and 4, see if the codes change.
    that said, I suspect it’s a fools errand. Head gasket failure on cyl’s 1 and 2 is sand-pounding common, more’n likely what’s happening.
    A boroscope for inspection of the combustion chambers and leak-down test, will help determine if head gasket is failing. A block tester test too, which detects exhaust gas in coolant.
    How many miles, and have you ever cleaned the Exhaust Gas Recirculation components, and the EGR passages in the intake manifold.
    For more info on cleaning the EGR see first link in my signature. If viewing on a phone turn it landscape orientation to see sig’s.
    #3 Mendel Leisk, Mar 8, 2022
  4. Kats_Pajamaz
    35
    ohio
    Sorry I left one out. It was 0300,0302,0303,0304. So cylinders 2,3, and 4 misfiring, but not 1. I also just changed the oil about 4 days prior and the oil came out looking normal. I haven't noticed any loss of coolant or discoloration. Before I got home, while I was still driving the car, the misfiring happened while idling, and at very low speed, but went away while driving it at 25+, maybe a bit lower. I just changed the spark plugs and while I was at it, I checked the coils and I looked into the wells and there was no sign of any liquid.
    I will definitely look into the head gasket though. That isn't a problem I want to leave there if it is the cause.
    #4 Kats_Pajamaz, Mar 8, 2022
  5. Mendel Leisk
    41,905
    I’d get it diagnosed soon: failing head gasket is likely, which leads to (incompressible) coolant in combustion chamber, which bends piston arms, and so on.
    what’s the miles btw?
  6. Kats_Pajamaz
    35
    ohio
    I think somewhere around 250k miles. I went ahead with the process of cleaning the egr system and intake manifold because i figured even if it isn't the cause, the previous owners havent seemed to keep up on maintenance, so it is long overdue. When I removed the egr cooler, it was almost 100% clogged. Barely a trickle of liquid would get through. I am still in the process of cleaning it because I don't really have $350 to drop on a new cooler right now.
    Unless any of the things I can check/test for a blown head gasket are any easier at my current state of disassembly, I'm going to have to reassemble once the cooler is cleaned out and then I'll try to run it again. If the codes pop again, first thing I'll go to will be a leakdown and block test.
  7. Kats_Pajamaz
    35
    ohio
    Update: Got the EGR and intake manifold cleaned and manually cleared the codes with my reader. I was getting worried that I wouldn't be able to get the cooler cleaned but an overnight soak in purple power and a pressure washer did the trick. No misfires on startup and no misfires or codes during the 6 hours I spent doordashing last night which involves a good combination of driving and idling. I am still keeping a close eye on signs of a bad head gasket though just in case.
