P0300 p0301 p0302 mystery
Discussion in 'Gen 3 Prius Main Forum' started by Bailey Zemora, Nov 21, 2018.
  1. Bailey Zemora
    Bailey Zemora New Member
    Indianapolis, IN
    Hello! If you Can help me, you are smarter than all the mechanics I live around! I just bought a 2010 Prius 3 with 194k on it. No issues when test driving, got it scanned and everything came back perfect....so I bought it!
    Well 2 days after the purchase my check engine light came on and my engine made that scary sound that Prius’s likes to make when it misfires. I had my sparks and coils checked out and the mechanic ~claimed~ it was faulty plugs. So I had them replace the plugs (yes the correct ones are in). They said the coils were fine. And the check engine light turned off
    100 miles later my engine starts misfiring again and the check is back on..I went to an actual hybrid car place to have my RVG (or whatever the heck it is) pipe and valve cleaned. Engine light turns off and then 100 miles later it’s back on again and misfiring!
    I cleaned the MAF sensor and made sure everything was connected correctly-it did nothing..
    I just had it scanned again with the same code. I just bought this and I’m at a loss :///
    amos likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    There’s a shop about 50 miles or so south of you in Scottsburg called Auto be Yours:).
    I’d give them a call, but it sounds like the egr circuit needs a thorough cleaning ;).
    Good luck and keep us posted (y).
    m.wynn likes this.
  3. BZzap!
    BZzap! Senior Member
    1,607
    878
    I second that motion. Probably RGR circuit needs to be cleaned( de-carboned).
    m.wynn and Raytheeagle like this.
  4. Bailey Zemora
    Indianapolis, IN
  5. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    You need to do the intake manifold and egr cooler;).
    Otherwise the job is incomplete and the results will not be what you expect as there is still carbon buildup there:cool:.
    Bailey Zemora and m.wynn like this.
  6. Bill Norton
    Bill Norton Senior Member
    2,215
    745
    MONW, Ks.
    2019 Prius
    L Eco
    What is the code number and description?
  7. Bailey Zemora
    Indianapolis, IN
    P0301 p0302 and p0300
  8. Bailey Zemora
    Indianapolis, IN
    Huh I will have to call a make sure he did the whole thing!
  9. Bailey Zemora
    Indianapolis, IN
    Just called and he did say he did both
  10. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Did he plug everything back in? Have you checked?
    Something isn’t right and if everything is cleaned, my bet is something isn’t plugged in, or you have a gross vacuum leak.
    Good luck and keep us posted.
    m.wynn and Bailey Zemora like this.
  11. Bailey Zemora
    Indianapolis, IN
    How do I check that???
    Raytheeagle likes this.
  12. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Basically double check all of their work;).
    Wouldn’t be the first time that something was claimed done and something wasn’t put completely together correctly :cool:.
    m.wynn likes this.
  13. BZzap!
    1,607
    878
    Did you take this car to a Certified Toyota mechanic or a guy down the street. If the mechanic that worked on your car isn’t 100% familiar with the Prius, he might be in the dark about the idiosyncrasies of the Prius. The procedures for cleaning the EGR circuit can be quite extensive. They can involve removing the entire intake manifold for proper cleaning. Also, with than many miles, the EGR assembly may even be defective.
    At this point, the best thing for you to do is take it to a Toyota dealer and have them diagnose it. You might even ask the if there is any type of assistance available. You never can tell.
    I know that you’re in between a rock and a hard spot but I don’t see any other recourse at this point.
  14. Bailey Zemora
    Indianapolis, IN
    I took it to a place specifically for hybrid cars he says he’s done tons of Prius work and he also said that my Prius was the nicest he’s ever seen as a used car. Hopefully he just forgot to plug something back in
    kc5dlo and Raytheeagle like this.
  15. BZzap!
    1,607
    878
    Hope so.
    Raytheeagle and Bailey Zemora like this.
  16. joe doe
    joe doe New Member
    conway nh
    You got scammed compression leak, how much antifreeze are you loosing?
    douglasjre likes this.
  17. douglasjre
    douglasjre Senior Member
    2,202
    736
    Null, NL
    Loosen radiator cap. If prob goes away the answers obvious
