P0300, P0301, P0302, P0103
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Triparadox, Mar 12, 2019.
  1. Triparadox
    Triparadox Active Member
    201
    108
    I just purchased a car not very long ago (within one month) and it showed me an engine light indicator. Once plugged with OBD2, it appeared that there were multiple misfiring from Cyl. 1 and Cyl. 2. I swapped both spark plugs and ignition coil as follow:
    1 to 4
    2 to 3
    I resetted the indicator. Today it came back again, still with Cyl. 1 and Cyl. 2 with an additional P0103 (MAF). Can anyone give me some suggestion???
  2. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    The misfires, at least at this point, may be due to the MAF issue. Address the MAF fault before addressing the misfires. If you have access to a scanner, check to make sure that you are seeing at least 1.8 g/sec at idle. There are probably better ways of testing a MAF but regardless, you need to address the MAF problem before the misfires.
    Raytheeagle likes this.
    52,372
    you're gonna get confused with two threads on the same problem
    Raytheeagle and The Critic like this.
  4. Triparadox
    201
    108
    Sure, I'll try to clean it when I have the time. I also tried to find the 2010 Prius cleaning MAF guidance.. No luck until now.. Mind helping me on that one?
    Yes. I was at phone the first time, so I didn't really see the troubleshoot section.
    #4 Triparadox, Mar 13, 2019
  5. Triparadox
    201
    108
    BTW there's an information I forget to add:
    Sometimes, when I start the engine up, there will be rattling vibration and sound for the first couple seconds (longest one was around 9 seconds). It's not always. If after that I turn off and turn the engine on again, it won't rattle. After a long period of time, there's a high chance it will rattle, but again, not always... like 75% chance.
  6. The Critic
    3,193
    2,333
    CA
    The MAF sensor is located on the backside of the air intake tube. IIRC it uses phillips screws. Remove and clean if you desire, but I have never had success with cleaning MAFs.
    How's your coolant level? In my experience if this engine suddenly develops a start-up rattle at high mileage, there is a high probability of headgasket failure.
  7. Triparadox
    201
    108
    I just refilled the coolant to the appropriate level last couple days.. I'll see tomorrow. What if it actually drops below the gauge? Is it head gasket failure? Is this easy to fix? Expensive?
  8. The Critic
    3,193
    2,333
    CA
    Not sure which "gauge" you are referring to. The easiest way to check for headgasket failure on these engines is to pressurize the cooling system overnight (with a pressure tester), then remove the spark plugs. Then use an inspection camera to inspect the tops of the pistons for signs of coolant intrusion.
  9. Triparadox
    201
    108
    I do not have the pressure tester... I'm complete beginner with limited access to tools.
  10. Triparadox
    201
    108
    Update: I just checked the coolant reservoir level. It's below LOW now even though I'm pretty sure I filled it up to the appropriate level couple days ago.
  11. FnRedPrius
    FnRedPrius Active Member
    100
    121
    Pilot, NC
    Coolant loss isn't always consistent with a head gasket failure. Ours went thru almost a gallon it just over a week, but since the problem became apparent in early December total loss has been about 2 gallons. As @The Critic said, wet piston tops after a cold soak will probably be the best indication.
