P0301 After Head Gasket Replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TwoPriusInTenn, Jan 2, 2021.
  1. TwoPriusInTenn
    254
    66
    Tennessee
    I replaced the headgasket on my daughter's 2012 Prius Two. Following the 6 -7 "test drives" I've taken it continues to register the P0301. I have replaced spark plugs, coils, cleaned the injectors and replaced the pcv valve.
    Could there be a problem with the ecu? Does it need to be reset? I'm at a loss as to what it could be.
  2. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Do a compression test. Perhaps you have a slightly bent rod from the coolant ingestion. Slightly bent rod may cause the piston to not reach the deck, resulting in lower compression in that cylinder. Inadequate compression will cause a misfire.
    Aaron Vitolins and Raytheeagle like this.
  3. TwoPriusInTenn
    254
    66
    Tennessee
    Thank you. I will do a compression test using my TechStream.
  4. The Critic
    3,193
    2,333
    CA
    Tech stream will do a relative compression test. Not as good as a real one, but it may suffice.
  5. Mendel Leisk
    42,205
    Was wondering about that.
  6. TwoPriusInTenn
    254
    66
    Tennessee
    Based on a little more research, it appears to be a bent rod in cylinder one. We are currently opting for an engine swap.
    Anyone know of a good step by step video on how this is done?
    My main concern is lining up the engine and the trans.
  7. Mendel Leisk
    42,205
    Check out @Ragingfit fits videos “fix that Prius” is his channel I think. Believe they’re linked in Prius v mod forum, pinned. Don’t let loc throw you off.
  8. TwoPriusInTenn
    254
    66
    Tennessee
    Thank you. I will check that out.
  9. TwoPriusInTenn
    254
    66
    Tennessee
    I wanted to provide an end result to these posts. Turned out to be a bent rod in cylinder one. My daughter decided to sell the car as opposed to replacing the engine.
    Thank you for your input and assistance.
    The Critic and Mendel Leisk like this.
  10. Mendel Leisk
    42,205
    Cylinder one turns up regular as rain. And Cylinder one Exhaust Gas Recirculation passage in the intake is first to clog, regular as rain.
    Ragingfit likes this.
