P0301 cylinder 1 misfire on Gen 2 after new Denso coil and new spark plug
Discussion in 'Gen 2 Prius Main Forum' started by Jose meza, Apr 23, 2022.
  1. Jose meza
    Jose meza Junior Member
    Orange County
    Any trouble shooting suggestions? No “lack of power” performance or fuel economy loss, no Gen 3 head gasket rattle either. Thanks for any input.
    48,945
    what plugs and where did you buy them?
  3. PriusCamper
    PriusCamper Senior Member
    10,897
    4,418
    Pacific Northwest, USA
    Lack of adequate engine lubrication can sometimes trigger a misfire code... Or a bad ignition coil can cause the problem, which you diagnose by moving the coil from misfiring cylinder to a different cylinder and see if misfire error moves to where you moved it or stays in place.
  4. Jose meza
    Orange County
    Denso iridium long life SK16R11 off Amazon
  5. Jose meza
    Orange County
    I replaced both the coil and the plug with denso products I put about 300 miles on it and the light came back. I change the oil every month because of my commute.
  6. dolj
    dolj Senior Member
    7,487
    3,763
    Wellington, New Zealand
    Just because it says Denso on the box doesn't mean it is a genuine Denso product. eCommerce sites are full of fake name-branded look-a-likes.
    Amazon does not put a whole lot of effort into ensuring counterfeit products are not being sold through their channels, sad to say. Maybe one day that will change. eBay is even worse.
    I'd suggest you pay a reasonable price at a bricks-and-mortar store and ensure you buy the real McCoy (genuine product).
    It is not hard to tell if a spark plug is genuine just by looking at it if you know what to look for. The counterfeiters put more effort into making the box look real than the actual plug. LOL.
  7. PriusCamper
    10,897
    4,418
    This is your likely answer... Though one time I did a full engine cleaning and tune up and new spark plugs on my Subaru that had a warped head and all the tinkering was enough to push the engine over the edge and could no longer find replacement heads so became a Prius driver instead.
    In terms of next steps, reinstall your old coil and plug in that cylinder to confirm it's counterfeit/defective parts and if problem is still the same it's time to do a bore scope and compression test to confirm engine is ok.
    Jose meza likes this.
  8. bisco
    48,945
    that was my concern as well
  9. Jose meza
    Orange County
    What’s a good compression number?
  10. Jose meza
    Orange County
    Should I try a plug from a brick and mortar store? I get that there are counterfeit parts, that’s why I avoided eBay. I read the entire description and saw that they were both genuine Denso products with multiple reviews that didn’t look like they were poorly translated.
  11. Jose meza
    Orange County
    Sorry forgot to mention that this morning 4/27/22 when I started the car I noticed a bit of a rattle once the engine kicked on. It didn’t last but more than 15 or so seconds and it didn’t come back during my hour and a half commute home north did the check engine light come on. I’m familiar with the Gen3 head gasket sound but is it the same loud shocking sound with the gen2? Thanks for your input guys
  12. bisco
    48,945
    dealer only, the supply chain is messed up
  13. PriusCamper
    10,897
    4,418
    Numbers that are near the same across all four cylinders is what matters most...
  14. ChapmanF
    15,072
    With Amazon, it doesn't seem to be necessarily useful even to go by seller reviews and pick a specific seller ... because if they have seller A and seller B who list the "same" item, and you order it "from" seller A, and Amazon sees that they have seller B's stock in a nearer warehouse, it's possible they might just send you that.
    The Automotive Anti-Counterfeiting Council whitepaper linked above kind of tiptoed around the actual name(s) of the "at least one" online marketplace that does that, but I'm pretty sure I've had it happen to me, when I ordered on you-know-where.
    PriusCamper likes this.
  15. PriusCamper
    10,897
    4,418
    That's relatively common with all Prius / atkinson-based engines.
  16. JahT
    JahT Member
    145
    75
    I had an engine rattle/shake at idle that was intermittent and came with CEL misfire codes for 1 and 3, I was worried it was a head gasket just from all of the Gen 3 videos. The rattle is not to be confused with the engine starting and lurching the car forward sometimes in park. I tried new plugs, coils, and fuel system cleaner with no luck, but a $40ish set of 4 refurbished fuel injectors solved my problem.
    Mine sounded like this:
